1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: usage of Java Channel Access Client
To: tech-talk <[email protected]>
Date: Wed, 22 Jan 2020 18:11:30 +0800 (GMT+08:00)
Hi all,
I use ca library to put PV value, there are about 300 PVs. Follow the instruction, I used descriptor to create and connect the PVs at once:
List<ChannelDescriptor<?>> descriptors = new ArrayList<> ();
 List<Channel<?>> channels;
for (Entry<String, String> ip_entry : ipMap.entrySet()) {
String ip = ip_entry.getValue();
for (Entry<Integer, String> port_entry : portMap.entrySet()) {
String port = port_entry.getValue();
String pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":StartTime";
descriptors.add(new ChannelDescriptor<String>(pv_name, String.class));
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":NextWriteTime";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":AvgProcDelay";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":WritePeriod";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":WriteDuration";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":PVNum";
descriptors.add(new ChannelDescriptor<Integer>(pv_name, Integer.class));
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":Connected";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":Disconnect";
pv_name = "ACC_RCS_CO:" + port + ":" + ip + ":WriteCount";
channels = Channels.create(context,  descriptors);
My question is how to use each channel to put value? I've not found any example. I have tried: channels.get(0).put("test"), it's not correct.(error info:The method put(capture#1-of ?) in the type Channel<capture#1-of ?> is not applicable for the arguments (String))
Any advice or suggestions would be appreciated.
Re: usage of Java Channel Access Client J. Lewis Muir via Tech-talk
Prev: RE: [EXTERNAL] Spring Meeting? chuzm--- via Tech-talk
Next: Oxford IC101 support? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: usage of Java Channel Access Client J. Lewis Muir via Tech-talk
