1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: XSPRESS3 hdf5 problems
From: John Dobbins via Tech-talk <[email protected]>
Date: Thu, 23 Jan 2020 16:55:50 +0000
Mark,
Thanks. I'll give that a try.
John
Sent: Thursday, January 23, 2020 11:27 AM
To: John Dobbins <[email protected]>
Cc: [email protected] <[email protected]>; Matt Newville <[email protected]>
Subject: RE: XSPRESS3 hdf5 problems
Hi John,
Ø  I have contacted Quantum.  I thought that while waiting to hear from them it would make sense to build an IOC from source. On github I see
Ø  epics-modules/xspress3
The IOC that Quantum distributes is ancient, using areaDetector R1-9-1.
That is the one I recommend you use.  Matt Newville in our group here at the APS is maintaining it.  It is working with the latest version of ADCore, ADSupport, etc.
It uses NDPluginROIStat for ROI statistics.
There are new OPI screens.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, January 23, 2020 8:15 AM
To: [email protected]
Subject: XSPRESS3 hdf5 problems
All,
I have a new 5 channel Quantum Xspress3 data readout unit which when taking multiple frames will start generating hdf5 related error messages at what seems like random (will acquire between a few or thousands of frames before generating errors).  Once these messages start they seem to continue until the IOC segfaults.
repeating pair of error messages on the IOC console:
 HDF5-DIAG: Error detected in HDF5 (1.8.12) thread 0:
  #000: ../../src/H5Dio.c line 231 in H5Dwrite(): can't prepare for writing data
    major: Dataset
    minor: Write failed
  #001: ../../src/H5Dio.c line 348 in H5D__pre_write(): file selection+offset not within extent
    major: Dataspace
    minor: Out of range
This IOC is a binary that comes with the detector.
and
quantumdetectors/xspress3-epics  forked from the above.
Any advice on which i should go with? Any suspicions regarding the hdf5 errors?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
XSPRESS3 hdf5 problems John Dobbins via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Prev: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Next: Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
