Subject: Re: XSPRESS3 hdf5 problems
From: Matt Newville via Tech-talk <[email protected]>
To: John Dobbins <[email protected]>
Date: Thu, 23 Jan 2020 11:04:50 -0600
Hi John,
Just to follow up: I don't recall ever seeing that error from HDF5 with epics-modules/xspress3.  I believe there were some known problems with HDF5 that were fixed around AD 2, but I don't recall the details.
On Thu, Jan 23, 2020 at 10:55 AM John Dobbins <[email protected]> wrote:
Mark,
Thanks. I'll give that a try.
John
Sent: Thursday, January 23, 2020 11:27 AM
Cc: [email protected] <[email protected]>; Matt Newville <[email protected]>
Subject: RE: XSPRESS3 hdf5 problems
Hi John,
Ø  I have contacted Quantum.  I thought that while waiting to hear from them it would make sense to build an IOC from source. On github I see
Ø  epics-modules/xspress3
The IOC that Quantum distributes is ancient, using areaDetector R1-9-1.
That is the one I recommend you use.  Matt Newville in our group here at the APS is maintaining it.  It is working with the latest version of ADCore, ADSupport, etc.
It uses NDPluginROIStat for ROI statistics.
There are new OPI screens.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, January 23, 2020 8:15 AM
To: [email protected]
Subject: XSPRESS3 hdf5 problems
All,
I have a new 5 channel Quantum Xspress3 data readout unit which when taking multiple frames will start generating hdf5 related error messages at what seems like random (will acquire between a few or thousands of frames before generating errors).  Once these messages start they seem to continue until the IOC segfaults.
repeating pair of error messages on the IOC console:
 HDF5-DIAG: Error detected in HDF5 (1.8.12) thread 0:
  #000: ../../src/H5Dio.c line 231 in H5Dwrite(): can't prepare for writing data
    major: Dataset
    minor: Write failed
  #001: ../../src/H5Dio.c line 348 in H5D__pre_write(): file selection+offset not within extent
    major: Dataspace
    minor: Out of range
This IOC is a binary that comes with the detector.
and
quantumdetectors/xspress3-epics  forked from the above.
Any advice on which i should go with? Any suspicions regarding the hdf5 errors?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
--Matt Newville
Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Prev: Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Next: RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
Next: Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
