Subject: Re: ezca for 3.15
From: "D. Peter Siddons via Tech-talk" <[email protected]>
Date: Mon, 3 Feb 2020 14:57:40 -0500
Hi Mark,
  Excellent! I've only ever used makeBaseApp to build IOC applications. I didn't realize it knows about clients. If all else fails, read the instructions :)
THanks again,
Pete.
On 2/3/20 2:06 PM, Mark Rivers wrote:
Hi Pete,
Rather than creating the Makefile yourself, it is easier to let EPICS create most of it for you.  I just successfully built your testenable application this way.  Here are the steps I followed.
Create a new application directory and cd to it
> mkdir testEnable
> cd testEnable
Run the makeBaseApp.pl perl script, telling it to create a caClient application type:
> /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeBaseApp.pl -b /usr/local/epics/base-7.0.3.1 -t caClient testEnable
Go to the configure directory and edit RELEASE
> cd ../configure/
(edit RELEASE and add a line like the following to tell it to look in the EPICS extensions directory.  It will look in the include/ directory for include files and the lib/linux-x86_64 directory for libraries.
EXTENSIONS = /usr/local/epics/extensions_new
Go to the testEnableApp directory and edit the Makefile.
> cd ../testEnableApp/
(modify the provided Makefile so it looks like this)
TOP=..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
PROD_HOST += testenable
testenable_SRCS += testenable.c
testenable_LIBS += ezca
testenable_LIBS += $(EPICS_BASE_HOST_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
To avoid compiler warnings I changed your testenable.c program to declare main() to return int, and added return 0;
#include <cadef.h>
#include <ezca.h>
int main()
int d;
int s[384];
   ezcaGet("det1.TSEN", ezcaLong, 384, &s);
   ezcaGet("det1.CHAN",ezcaLong,1,&d);
   s[d]=1;
  ezcaPut("det1.TSEN", ezcaLong, 1, s);
  return 0;
} /* end main() */
Then I just typed "make" and it built fine.
corvette:~/devel/testEnable/testEnableApp>make
perl -CSD /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/home/epics/devel/testEnable/testEnableApp/O.linux-x86_64'
perl -CSD /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m testenable.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/usr/local/epics/extensions_new/include -I/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/usr/local/epics/base-7.0.3.1/include/os/Linux -I/usr/local/epics/base-7.0.3.1/include        testenable.o ../testenable.c
make[1]: Leaving directory `/home/epics/devel/testEnable/testEnableApp/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/usr/local/epics/extensions_new/include -I/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/usr/local/epics/base-7.0.3.1/include/os/Linux -I/usr/local/epics/base-7.0.3.1/include        -c ../testenable.c
/usr/bin/g++ -o testenable  -L/home/epics/devel/testEnable/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -L/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/testEnable/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64           -rdynamic -m64         testenable.o    -lezca -lca -lCom
Installing created executable ../../bin/linux-x86_64/testenable
Sent: Monday, February 3, 2020 11:51 AM
Hi Mark,
   Added cadef.h and get:
gcc -c -fPIC -I/home/peter/epics/extensions/include -I/home/peter/epics/base/include -I/home/peter/epics/base/include/os/Linux testenable.c
In file included from /home/peter/epics/base/include/epicsTypes.h:19:0,
                 from /home/peter/epics/base/include/caerr.h:31,
                 from /home/peter/epics/base/include/cadef.h:48,
                 from testenable.c:1:
/home/peter/epics/base/include/compilerDependencies.h:19:10: fatal error: compilerSpecific.h: No such file or directory
 #include "compilerSpecific.h"
compilation terminated.
I hacked a Makefile, and the above was generated when I used it. I got the same error when I used the single compile line I had before. I've attached the c file and the makefile. Any suggestions?
Pete.
Sent: Saturday, February 1, 2020 5:13 PM
To: Siddons, David <mailto:[email protected]>
Cc: tech-talk <mailto:[email protected]>
Hi Peter,
You need this to add this line in your program:
#include <cadef.h>
before
#include <ezca.h>
Because ezca.h uses chid, it should really be including cadef itself.  But it doesn't.
Sent: Saturday, February 1, 2020 3:53 PM
To: Mark Rivers
Cc: tech-talk
Hi Mark,
   OK, I rebuilt my extensions directory, and built ezca. All went well. When I try to use ezca I hit problems. Here is my simple program; it reads a vector, changes one element and then writes it back:
#include <ezca.h>
main()
int d;
int s[384];
   s[d]=1;
and my compile line:
gcc -o testenable -L/home/peter/epics/extensions-master/lib -I/home/peter/epics/extensions-master/include -I//home/peter/epics/base-3.15.6/include/ -lezca testenable.c
which gets me:
In file included from testenable.c:1:0:
/home/peter/epics/extensions-master/include/ezca.h:77:61: error: unknown type name ‘chid’; did you mean ‘void’?
 epicsShareFunc int epicsShareAPI ezcaPvToChid(char *pvname, chid **cid);
                                                             void
/home/peter/epics/extensions-master/include/ezca.h:103:2: error: unknown type name ‘TS_STAMP’
  TS_STAMP *timestamp, short *status, short *severity);
/home/peter/epics/extensions-master/include/ezca.h:107:45: error: unknown type name ‘TS_STAMP’
  char ezcatype, int nelem, void *data_buff, TS_STAMP *timestamp,
testenable.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
 main()
So what am I doing wrong?
Pete.
Sent: Saturday, February 1, 2020 3:56 PM
Hi Pete,
I suspect you may be using an old version of ezca?  The latest version is here:
https://github.com/epics-extensions/extensions
<https://github.com:epics-extensions/extensions>
I just built successfully with that version on base 7.0.3.1, so I am pretty sure 3.15 will build fine as well.
Here is the output when building:
corvette:extensions_new/src/ezca>make
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[1]: Entering directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m ezca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           ezca.o ../ezca.c
make[1]: Leaving directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           -c ../ezca.c
../ezca.c: In function 'pop_channel':
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
    sizeof(struct channel)*NODESPERMAL, Channel_avail_hdr);
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_monitor':
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct monitor)*NODESPERMAL, Monitor_avail_hdr);
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_work':
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct work)*NODESPERMAL, Work_avail_hdr);
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
/usr/bin/ar -rc    libezca.a    ezca.o
/usr/bin/ranlib libezca.a
/usr/bin/g++ -o libezca.so -shared -fPIC -Wl,-hlibezca.so -L/usr/local/epics/extensions_new/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         ezca.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libezca.so
Installing library ../../../lib/linux-x86_64/libezca.a
Cheers,
From: Tech-talk <mailto:[email protected]> on behalf of Siddons, David via Tech-talk <mailto:[email protected]>
Sent: Saturday, February 1, 2020 2:33 PM
To: EPICS Tech Talk
Subject: ezca for 3.15
I want to use ezca with 3.15, but it seems to be a mess of missing header files, presumably things dropped with 3.15 (e.g. tsDefs.h, cadef.h). Has anyone made it work?
Pete.
ezca for 3.15 Siddons, David via Tech-talk
Re: ezca for 3.15 Mark Rivers via Tech-talk
Re: ezca for 3.15 Siddons, David via Tech-talk
RE: ezca for 3.15 Mark Rivers via Tech-talk
Prev: RE: ezca for 3.15 Mark Rivers via Tech-talk
Next: Job opening at PSI (Control System Engineer / SW developer) Celcer Tine (PSI) via Tech-talk
