1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: areaDetector crashes EPICS IOC and autosave failure
To: 'Jong Woo Kim' <[email protected]>
Cc: "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 5 Feb 2020 23:11:52 +0000
Hi Jong Woo,
What model Eiger are you using?  Is it from Dectris?
You said you were running R2-7 of ADEiger.  This is not possible R2-7 has not been tagged yet.  Are you running the current master branch, or R2-6?
Something is wrong, because your gdb traceback shows that eigerDetector.cpp line 871 is calling eigerParam::get.
In the master branch of eigerDetector.cpp line 871 is the first line below.  In R2-6 line 871 is the second line below.  Neither are calling eigerParam::get().
        if(adStatus == ADStatusAcquire || (adStatus == ADStatusAborted && success))
            setIntegerParam(ADStatus, ADStatusIdle);
Please verify what version of ADEiger you have.  Are you running a git clone?  If so please type
git status
git diff R2-6 eigerDetector.cpp
Sent: Wednesday, February 5, 2020 4:41 PM
Cc: Jennings, Guy <[email protected]>; [email protected] >> EPICS Tech Talk <[email protected]>
Subject: Re: areaDetector crashes EPICS IOC and autosave failure
Hi Mark,
Thank you so much. I followed exactly what you said and I've got the followings
(gdb) backtrace
#0  EigerParam::get (this=0x0, value="") at ../eigerParam.cpp:410
#1  0x000000000050fe8c in eigerDetector::controlTask (this=0x16f8290) at ../eigerDetector.cpp:871
#2  0x0000000000fecc0c in start_routine (arg=0x1709ea0) at ../../../src/libCom/osi/os/posix/osdThread.c:403
#3  0x00007ffff7402ea5 in start_thread () from /lib64/libpthread.so.0
#4  0x00007ffff62ba8cd in clone () from /lib64/libc.so.6
Best,
Jong Woo
Sent: Wednesday, February 5, 2020 3:04 PM
To: Jong Woo Kim <
[email protected]>
Cc: Jennings, Guy <
For me on Centos 7 (very similar to RHEL 7) I get core.xxxxx files in the current working directory.  I am not sure what I set up to get that, nothing that I remember.
However, you don’t need to get a core file at all, you can just run your IOC under gdb to start with.
Type the following:
gdb [path_to_ioc_application]
where [path_to_ioc_application] is the command you normally type to start the IOC, but without the second st.cmd argument.
Once you get the gdb prompt type
run st.cmd
Then when the IOC crashes you can type the command:
backtrace
Sent: Wednesday, February 5, 2020 2:50 PM
To: Mark Rivers <
[email protected]>
Cc: Jennings, Guy <
Red hat enterprise linux 7.
Sent: Wednesday, February 5, 2020 1:45:36 PM
To: Jong Woo Kim <
[email protected]>
Cc: Jennings, Guy <
What version of Linux are you running?
Sent from my iPhone
On Feb 5, 2020, at 2:16 PM, Jong Woo Kim via Tech-talk <
[email protected]<mailto:[email protected]>> wrote:
Thank you Mark, Michael and Guy.  But I couldn't find any core dump files. There is folder /var/lib/systemd/coredump. But there is nothing in there. I also used the command 'coredumpctl'. I think something should appear if any.
$ coredumpctl list
No coredumps found.
The message keeps saying like below.
Segmentation fault (core dumped)
What's wrong?
Sent: Wednesday, February 5, 2020 6:39 AM
To: Jong Woo Kim <
[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> >> EPICS Tech Talk <[email protected]<mailto:[email protected]>>
To get a core dump out of systemd use the coredumpctl command.
See
man coredumpctl
or try
coredumpctl debug
> On Feb 4, 2020, at 4:56 PM, Jong Woo Kim via Tech-talk <
> Hi Mark,
> Thank you so much for letting me know. I could not find "core" in eigerDetectorApp or in any folder around it. Instead, I found systemd-coredump in  "/usr/lib/systemd/systemd-coredump".
> The following is the result of running gdb and bt. It seems okay to me. Is this a wrong file?
> $ gdb systemd-coredump
> GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7
> Copyright (C) 2013 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
https://urldefense.proofpoint.com/v2/url?u=http-3A__gnu.org_licenses_gpl.html&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=5SqrqeDD_u5q7YAVAq3G5t22J2QiTSh0ygG4_hwdBFM&e= >
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-redhat-linux-gnu".
> For bug reporting instructions, please see:
https://urldefense.proofpoint.com/v2/url?u=http-3A__www.gnu.org_software_gdb_bugs_&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=yiatgN5YlRyxrEDD5VI0j6rOEa6rPgM-oDRq8LFNNNQ&e= >...
> Reading symbols from /usr/lib/systemd/systemd-coredump...Reading symbols from /usr/lib/systemd/systemd-coredump...(no debugging symbols found)...done.
> Missing separate debuginfos, use: debuginfo-install systemd-219-67.el7_7.2.x86_64
> (gdb) bt
> No stack.
> From: Mark Rivers <
> Sent: Friday, January 31, 2020 4:56 PM
> To: Jong Woo Kim <
> Cc:
[email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
> Hi Jong Woo,
> Ø  $ gdb /path/to/ADEiger_executable core     --- > coredump doesn't work either
> I was not clear in my instructions. “/path/to/ADEiger_executable” is not what you should type, you should type the actual path, which is probably something like:
> EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/bin/linux-x86_64/eigerDetectorApp.
> And “core” is the name of the actual core.* file that was created when you got the core dump message when the IOC crashed. It is probably in your iocBoot/iocEiger directory.  But on some systems it can be put in /var or somewhere else.
> Mark
> From: Jong Woo Kim <
> Sent: Friday, January 31, 2020 5:45 PM
> To: Mark Rivers <
> Cc:
> Hi Mark,
> Thank you so much. I resolved first two issues. But I'm still working on the last one 'eigerDetector crashes EPICS IOC'  ( e.i. Segmentation fault (core dumped) )
> I wasn't able to find where it crashed. The following is the message I've got.
> Note that the version of areaDetector, ADEiger, ADCore and EPICS base are R3-7, R2-7, R3-8, 3-15-6, respectively.
> We're using FileWriter interface to save data files.
> ____________________________________________________________
> /path/to/ADEiger_executable: No such file or directory.
> .../EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/iocBoot/iocEiger/autosave/core: No such file or directory.
> (gdb)
> I researched for coredump files
> .../systemd/coredump.conf
> .../bin/coredumpctl
> .../bin/systemd-coredumpctl
> .../lib/systemd/systemd-coredump
> .../share/bash-completion/completions/coredumpctl
> .../share/man/man1/coredumpctl.1.gz
> .../share/man/man5/coredump.conf.5.gz
> .../share/man/man5/coredump.conf.d.5.gz
> .../share/man/man8/systemd-coredump.8.gz
> .../share/zsh/site-functions/_coredumpctl
> .../include/config/coredump.h
> .../include/config/dev/coredump.h
> .../include/config/want/dev/coredump.h
> .../include/linux/coredump.h
> .../include/linux/devcoredump.h
> .../lib/systemd/coredump
> This is one of examples that results from gdb.
> $ gdb /var/lib/systemd/coredump
> /var/lib/systemd/coredump: Success.
> From: Mark Rivers <
> Sent: Thursday, January 30, 2020 10:35 AM
> To: Jong Woo Kim <
> Cc: Jong Woo Kim <
[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
> Hi Jong Woo,
> You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
> Ø  a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
> Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
> #file "sseqRecord_settings.req",     P=$(P),  S=AcquireSequence
> If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
> #set_requestfile_path("$(CALC)/calcApp/Db")
> Ø  b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
> Ø  ../save_restore.c(1774): [0xd]=write_it:Permission denied
> That error seems pretty simple.  It is a file permission problem.  The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application.  Fix the file permissions.
> Ø  c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message)
> Ø  Actually data hasn't been collected
> You have a core dump file.  You need to run gdb on that to find where it crashed.
> Run this:
> gdb /path/to/ADEiger_executable core.xxx
> where core.xxx is the name of your core dump file.  Once you get the gdb> prompt type this command
> backtrace
> Mark
> From: Tech-talk <
[email protected]<mailto:[email protected]>> On Behalf Of Jong Woo Kim via Tech-talk
> Sent: Thursday, January 30, 2020 10:33 AM
> To:
> Cc: Jong Woo Kim <
[email protected]<mailto:[email protected]>>; Jong Woo Kim <[email protected]<mailto:[email protected]>>
> Subject: areaDetector crashes EPICS IOC and autosave failure
> Hello,
> When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
> In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
>      I made sure that this file has contents and it is in a right folder
>           support/calc-R3-7-3/calcApp/Db/sseq_settings.req
>           support/calc-R3-7-3/db/sseq_settings.req
>      It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
> --------------------------------------------------- Message on monitor--------------------------------------------------------------
> ## EPICS R3.15.6
> ## EPICS Base built Dec  2 2019
> reboot_restore: entry for file 'auto_settings.sav'
> reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
> *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
> save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
> save_restore: Can't write backup file.
> 2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
> EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
> Bad init_rec return value  PV: EIG1:cam1:FWClear ao: init_record
> *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
> reboot_restore: done with file 'auto_settings.sav'
> iocRun: All initialization complete
> # Avoid deluge of messages when debugging
> #dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
> # save things every thirty seconds
> create_monitor_set("auto_settings.req", 30, "P= EIG1:")
> save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
> epics> save_restore: Can't connect to all status PV(s)
> auto_settings.sav: 1330 of 1330 PV's connected
> save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
> save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
> save_restore:write_save_file: Can't write save file. [200127-151357]
> save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
> save_restore:write_save_file: Can't write save file. [200127-151427]
> [iocEiger]$
Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Jennings, Guy via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Prev: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
