Subject: lock/unlock mutex problem
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Thu, 6 Feb 2020 14:41:30 +0000
I’ve run into a particular problem that I haven’t been able to figure out yet.
I’m debugging a device driver that uses a number of concurrent threads for operation
This is with epics 3.15.7.
I have these routines in my code
In my class definition, I’ve got:
char locker[80];                 // Store name of routine that called the lock/unlock
epicsMutex *mutex;      // Mutex for concurrent access control
The instantiation routine invokes:
this->mutex = newEpicsMutex;
The code in my class includes:
/** Lock the variable for concurrent access */
void driver::lock(const char *caller)
                bool flag;
                unsigned int lockedflag=0;
                do
                                flag = this->mutex->tryLock();
                                if(!flag)
                                                lockedflag++;
                                                if((!(lockedflag %10) && lockedflag < 100) || (!(lockedflag %100) && lockedflag < 1000) || (!(lockedflag % 1000) && lockedflag < 10000) )
        outputConsoleMessage(SHOW_ERROR_MESSAGES,"Driver::lock() - was called by %s->%s, but the variable has been locked by \"%s\" for %f secs!\n",caller, this->rec->name, locker, 0.01*lockedflag);
                                                epicsThreadSleep(0.01);
                while(!flag);
                strncpy(locker,caller,sizeof(locker) );
/** Unock the variable for concurrent access */
void driver::unlock(const char *caller)
                this->mutex->unlock();
                strncpy(locker,"Unlocked", sizeof(locker));
There are a number of lock/unlock pairs in the code that lock/unlock access to retrieved data.
After some period of time, which may be as short as a few minutes, or as long as many hours, I start getting errors like this:
2020/02/05 18:44:42.6571 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.010000 secs!
2020/02/05 18:44:42.6694 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.020000 secs!
2020/02/05 18:44:42.6802 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.030000 secs!
2020/02/05 18:44:42.6911 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.040000 secs!
2020/02/05 18:44:42.7020 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.050000 secs!
2020/02/05 18:44:42.7128 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.060000 secs!
2020/02/05 18:44:42.7237 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.070000 secs!
2020/02/05 18:44:42.7345 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.080000 secs!
2020/02/05 18:44:42.7453 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.090000 secs!
2020/02/05 18:44:42.7562 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.100000 secs!
2020/02/05 18:44:42.8643 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.200000 secs!
2020/02/05 18:44:42.9725 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.300000 secs!
2020/02/05 18:44:43.0858 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.400000 secs!
2020/02/05 18:44:43.1941 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.500000 secs!
2020/02/05 18:44:43.3022 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.600000 secs!
2020/02/05 18:44:43.4105 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.700000 secs!
2020/02/05 18:44:43.5187 Driver::lock() - was called by Driver::retry->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.800000 secs!
2020/02/05 18:44:43.6072 Driver::lock() - was called by Driver::setProcessRecord->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.010000 secs!
2020/02/05 18:44:43.6181 Driver::lock() - was called by Driver::setProcessRecord->_DSC_CHW:VFC_N2000:CI_CSET_RBV, but the variable has been locked by "Unlocked" for 0.020000 secs!
2020/02/05 18:44:43.6269 Driver::lock() - was called by Driver::clear_retry_count->CT1, but the variable has been locked by "Driver::thread_main" for 0.900000 secs!
Now, this driver has been working on 3.15.2, but when updated to 3.5.7, all of a sudden I’ve got this problem.
I don’t see how the mutex can be locked when the routine shows it is “Unlocked”.
Please, someone see something I don’t!
Thanks-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
Re: lock/unlock mutex problem Johnson, Andrew N. via Tech-talk
Prev: Re: ADVimba wrong camera initialization Kacper Klys via Tech-talk
Next: Re: ThorLabs motor driver Mark Rivers via Tech-talk
Prev: Re: ThorLabs motor driver Mark Rivers via Tech-talk
Next: Re: lock/unlock mutex problem Johnson, Andrew N. via Tech-talk
