I am writing a motor driver for an old piece of french equipment called EuroMove.
This is going well. But the thing does not implement homing in the controller. I try
to implement this in the asynAxis driver. To that purpose, I need the motor resolution.
It is in principle there, in the MRES field of the motor record. I tried:
pC_->getDoubleParm(axisNo_, pC_->motorResolution_, &resolution);
but this gave me a 0 instead of the .01 to which the MRES field had been configured in the
motor substitutions file. I know the record sees this because the conversion for physical
units to motor steps is working.
I also tried motorEncoderRatio_ which returned infinity.
My question now is how I can get at that information in an asynMotorAxis driver?
Or is my only option to write a configuration command or axis creation command which
passes the resolution value in?
This is against base3.14.12 and motor6.9 on RHEL7 linux.
Best Regards,
Mark Koennecke
- Re: asynMotorAxis Mark Rivers via Tech-talk
Re: lock/unlock mutex problem Johnson, Andrew N. via Tech-talk
<2020>
2025
2026
Re: send/receive waveform over network. Tomasz Brys via Tech-talk
<2020>
2025
2026
