Subject: Re: send/receive waveform over network.
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Fri, 14 Feb 2020 09:26:10 +0000
Thank you Mark for your help.
I solve my problem. And now everything works for me. I did many small mistakes which all together made my diagnosis difficult. I looked at the test examples of asyn driver, especially on asynPortClient, asynPortDriver and asynPortConnect. By reading those examples and digging the source I was able to understand how it works.
Thank you very much
Tomasz
Ps. I did not see the interface asynInt32 error message.
On 2020-02-147 w:7, 00:35, "Mark Rivers" <[email protected]> wrote:
    Hi Tomasz,
    I believe that when you started your IOC you should have seen an error message printed during iocInit, because devAsynInt32.c would not have found the asynInt32 interface.  This is where the error is printed:
    /* Get interface asynInt32 */
        pasynInterface = pasynManager->findInterface(pasynUser, asynInt32Type, 1);
        if (!pasynInterface) {
            printf("%s %s::%s findInterface asynInt32Type %s\n",
                         pr->name, driverName, functionName,pasynUser->errorMessage);
    Do you see that error message?
    Sent: Wednesday, February 12, 2020 8:54 AM
    To: 'Tomasz Brys'
    Cc: [email protected]
    Subject: RE: send/receive waveform over network.
    Hi Tomasz,
    The problem is that you are trying to send data on the asynInt32 interface to the drvAsynIPPort driver.  That driver does not support the asynInt32 interface, it only supports the asynOctet and asynOption interfaces.
    You can write and read your FPGA data by using a waveform record of type "char" and the asynOctetWrite and asynOctetRead device support.
    -----Original Message-----
    Sent: Tuesday, February 11, 2020 11:29 AM
    Hi Mark,
    I am sorry for confusing you. Yes, I need both, I need to write few MB and I need to read few MB. My device is a FPGA board with a custom protocol with handshake based on UDP. This is the reason why I do not want to use a stream device. The UDP packets in the custom protocol are numbered. The FPGA is connected directly to a dedicated PC.
    I have two problems:
    1. How to send/receive a single record via TCP/UDP not using a stream device. I have record like this:
    record(longout, "p") {
               field(VAL, "1")
               field(DTYP, "asynInt32")
               field(OUT,  "@asyn(det-stream)")
    With configuration: drvAsynIPPortConfigure("det-stream", "localhost:7777") I have a server written in python listening on port 7777.
    If I do "dbpf p 30" it does not send anything. What I am doing wrong? Do I have to write dedicated asynDriver?
    2. Write an asynDriver and parse message from the FPGA device to support handshaking. I can write asynDriver if I solve the first problem.
    I hope is much clearer now.
    Regards
    Tomasz
    On 2020-02-066 w:6, 18:58, "Mark Rivers" <[email protected]> wrote:
        Hi Tomasz,
        I am a little confused. You original post saint you wanted to send a big waveform from the IOC to the external device. But your second message said you want to receive a large waveform from the external device. Do you need to do both?
        I think Stream Device can do both of these. But if you need to parse a message from the device in order to know how much data it will send that is beginning to sound complex enough that you might want to write a driver using asynPortDriver.  You will use an underlying drvAsynIPPort driver to do the actual I/O.
        There are examples of doing this in a number of drivers, for example the drvTetrAMM driver in the quadEM module, or the marCCD driver in areaDetector.
        What type of device are you talking to?
        Sent from my iPhone
        > On Feb 6, 2020, at 11:40 AM, Tomasz Brys <[email protected]> wrote:
        > Hi Mark,
        > Thanks for you answer.
        > Maybe I simplified too much my problem. The device is sending 16-bytes packets. I do not know in advance how many packets I will receive. I will know it after I analyze the first packet and proper response for it. Then I can get even MB of data. Is a stream device with interpose function still appropriate tool for that?
        > Anyhow, How should I write my record from the previous email?
        > Regards
        > Tomasz
        > On 2020-02-066 w:6, 18:15, "Tech-talk on behalf of Mark Rivers via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
        >    Forgot to CC tech-talk.
        >    Sent from my iPhone
        >    Begin forwarded message:
        >    From: Mark Rivers <[email protected]<mailto:[email protected]>>
        >    Date: February 6, 2020 at 11:11:17 AM CST
        >    To: Tomasz Brys <[email protected]<mailto:[email protected]>>
        >    Hi Tomasz,
        >    There is no limitation that prevents Stream Device from sending a large waveform. In fact I have done so with the Tabor waveform generator in the synApps "ip" module.
        >    https://github.com/epics-modules/ip/blob/master/ipApp/Db/Tabor8024.proto
        >    Mark
        >    Sent from my iPhone
        >    On Feb 6, 2020, at 11:02 AM, Tomasz Brys via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
        >    Hi
        >    I have a beginner question. I want to send via ethernet (TCP/UDP) a waveform from IOC to external device. The waveform consists of binary data and can be big so the Stream Device is not a solution. To simplify the problem, I tested it with longout and a local server listening on port 7777.
        >    In my startup command I have:
        >    Then I load my db, which is very simple:
        >       field(VAL, "1")
        >    I started IOC, no errors. But how I can send the VAL over TCP?
        >    "dbpf p 2" does not work, neither "dbpf p.PROC"
        >    Do I have to write my own implementation of asynDriver?
        >    Is it any differences between sending longout and waveform?
        >    Regards
        >    Tomasz
send/receive waveform over network. Tomasz Brys via Tech-talk
Fwd: send/receive waveform over network. Mark Rivers via Tech-talk
Re: send/receive waveform over network. Mark Rivers via Tech-talk
Re: send/receive waveform over network. Tomasz Brys via Tech-talk
RE: send/receive waveform over network. Mark Rivers via Tech-talk
Prev: Re: send/receive waveform over network. Mark Rivers via Tech-talk
Next: MRF Delay Compensation Function Shen, Guobao via Tech-talk
Next: asynMotorAxis Koennecke Mark (PSI) via Tech-talk
