I know the resolution is available to the Newport XPS driver, because it uses it for profile moves.
I forget how I did that, and don’t have good search tools available from my phone. I seem to recall functions at some layer that send that motor record information to the drivers. Search for motorResolution in MotorSrc and NewportSrc.
Sent from my iPhone
> On Feb 7, 2020, at 10:33 AM, Koennecke Mark (PSI) via Tech-talk <[email protected]> wrote:
> Hi,
> I am writing a motor driver for an old piece of french equipment called EuroMove.
> This is going well. But the thing does not implement homing in the controller. I try
> to implement this in the asynAxis driver. To that purpose, I need the motor resolution.
> It is in principle there, in the MRES field of the motor record. I tried:
> pC_->getDoubleParm(axisNo_, pC_->motorResolution_, &resolution);
> but this gave me a 0 instead of the .01 to which the MRES field had been configured in the
> motor substitutions file. I know the record sees this because the conversion for physical
> units to motor steps is working.
> I also tried motorEncoderRatio_ which returned infinity.
> My question now is how I can get at that information in an asynMotorAxis driver?
> Or is my only option to write a configuration command or axis creation command which
> passes the resolution value in?
> This is against base3.14.12 and motor6.9 on RHEL7 linux.
> Best Regards,
> Mark Koennecke
- Re: asynMotorAxis Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
- Re: asynMotorAxis Mark Rivers via Tech-talk
- asynMotorAxis Koennecke Mark (PSI) via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
