1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: asynMotorAxis
Cc: "Koennecke Mark \(PSI\)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Feb 2020 11:41:59 +0000
Search for motorRecResolution. That is what the parameter is called.
Sent from my iPhone
> On Feb 7, 2020, at 11:05 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> I know the resolution is available to the Newport XPS driver, because it uses it for profile moves.
> I forget how I did that, and don’t have good search tools available from my phone. I seem to recall functions at some layer that send that motor record information to the drivers. Search for motorResolution in MotorSrc and NewportSrc.
> Mark
> Sent from my iPhone
>> On Feb 7, 2020, at 10:33 AM, Koennecke Mark (PSI) via Tech-talk <[email protected]> wrote:
>> Hi,
>> I am writing a motor driver for an old piece of french equipment called EuroMove.
>> This is going well. But the thing does not implement homing in the controller. I try
>> to implement this in the asynAxis driver. To that purpose, I need the motor resolution.
>> It is in principle there, in the MRES field of the motor record.  I tried:
>> pC_->getDoubleParm(axisNo_, pC_->motorResolution_, &resolution);
>> but this gave me a 0 instead of the .01 to which the MRES field had been configured in the
>> motor substitutions file. I know the record sees this because the conversion for physical
>> units to motor steps is working.
>> I also tried motorEncoderRatio_ which returned infinity.
>> My question now is how I can get at that information in an asynMotorAxis driver?
>> Or is my only option to write a configuration command or axis creation command which
>> passes the resolution value in?
>> This is against base3.14.12 and motor6.9 on RHEL7 linux.
>> Best Regards,
>>    Mark Koennecke
asynMotorAxis Koennecke Mark (PSI) via Tech-talk
Re: asynMotorAxis Mark Rivers via Tech-talk
Prev: Re: asynMotorAxis Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: asynMotorAxis Koennecke Mark (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
