Subject: Re: SNCSEQ Error Windows
From: Benjamin Franksen via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 11 Feb 2020 16:12:46 +0100
Am 11.02.20 um 15:21 schrieb Hetz, Benjamin via Tech-talk:
> Strange using 2.2.5 works like a charm. 2.2.8 not.
Indeed this is quite strange. The build rules haven't changed at all
between 2.2.5 and 2.2.8.
Freddie, can you look into that? I cannot reproduce the problem on Linux.
>>> I am using the Windows build of EPICS with VS compiler and Strawbery Perl.
>>> Compiling SNCSeq 2.2.8 went fine and also its demo/example files were
>>> build in seq-2_2_8\examples and running.
>>> Following the instruction from https://www-
>>> csr.bessy.de/control/SoftDist/sequencer/Compiling.html I created an
>>> example IOC and changed SNCSEQ in configure/REALESE to
>>> "C:/opt/epics/base-7_0_3/modules/seq-2_2_8".
>>> Running now gmake in the example ioc top dir yields following error:
>>> gmake[3]: *** No rule to make target 'sncExample.obj', needed by
>>> 'interlocksSupport.lib'.  Stop.
>>> gmake[3]: Leaving directory
>>> 'C:/opt/epics/interlocks/interlocksApp/src/O.windows-x64-static'
>>> gmake[2]: *** [C:/opt/epics/base-7_0_3/configure/RULES_ARCHS:58:
>>> install.windows-x64-static] Error 2
>>> gmake[2]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src'
>>> gmake[1]: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
>>> src.install] Error 2
>>> gmake[1]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp'
>>> gmake: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
>>> interlocksApp.install] Error 2
>>> May anyone please help?
>>> Thank you, Ben
Attachment: signature.asc
Description: OpenPGP digital signature
RE: SNCSEQ Error Windows Freddie Akeroyd - UKRI STFC via Tech-talk
SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Prev: StreamDevice Raw converter Henrique Silva via Tech-talk
Next: Re: Building EPICS base/IOC only for cross target Michael Davidsaver via Tech-talk
Prev: RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Next: RE: SNCSEQ Error Windows Freddie Akeroyd - UKRI STFC via Tech-talk
