Hi Sandeep,
The error you are getting is one I have never seen before.
> dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1")
> Error: syntax error
> at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660
> dbReadCOM: Parser stack dirty w/o error. 1
It seems like something is wrong on your end. I know of a number of sites are running with 7.0.3.1 and ADCore R3-8 or master branch and are not seeing this problem.
What is your EPICS_HOST_ARCH?
I wonder if there is some problem with line endings on startup script or template files. Can you run dos2linux on your startup script and any template files you have edited to try to remove any DOS line endings?
From: Sandeep Kumar Malu - UKRI STFC <[email protected]>
Sent: Saturday, February 22, 2020 2:55 AM
To: Mark Rivers
Cc: tech-talk
Subject: RE: Areadetector error in version R3-8
Hi Mark
You were right, I was on master branch in ADCore but then I checkout to R3-8 and error still remain same though the error line now in 656.
I also compiled with base 7.0.3, Asyn 4-38 & areadetector 3-8. The error again remains the same.
Thanks
Sandeep
-----Original Message-----
Sent: Friday, February 21, 2020 2:07 PM
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Cc: tech-talk <[email protected]>
> Also FYI, for me line no 660 points to field(PORT, $(PORT)) in
> ADBase.template file
If that is true then you are not using ADCore R3-8, which you said you were in your original message.
Here is the proof:
corvette:ADCore/ADApp/Db>git checkout R3-8 ADBase.template corvette:ADCore/ADApp/Db>cat -n ADBase.template
1 #=================================================================#
2 # Template file: ADBase.template
3 # Database for area detector control using asyn driver and standard asyn device support
4 # Mark Rivers
5 # March 9, 2008
6
649 ###################################################################
650 # The asynRecord is used for mainly for trace mask #
651 ###################################################################
652
653 # Set ASYN_TRACEIO_HEX bit by default
654 record(asyn,"$(P)$(R)AsynIO")
655 {
656 field(PORT, $(PORT))
657 field(TIB2,"1")
658 info("ADType", "ADDriver")
659 }
660
So in R3-8 line 660 is blank.
However, if I checkout the master branch of ADBase.template I see this:
653 ###################################################################
654 # The asynRecord is used for mainly for trace mask #
655 ###################################################################
656
657 # Set ASYN_TRACEIO_HEX bit by default
658 record(asyn,"$(P)$(R)AsynIO")
659 {
660 field(PORT, $(PORT))
661 field(TIB2,"1")
662 info("ADType", "ADDriver")
663 }
664
So I think you may be running the master branch of ADCore.
I am running the master branch and I don't see your error.
It will be interesting to see if the problem goes away if you run base 7.0.3.1.
Sent: Friday, February 21, 2020 7:40 AM
To: Mark Rivers <[email protected]>
Subject: Re: Areadetector error in version R3-8
Hi Mark
I used base 3.15 for areadetector 3-5 and asyn 4-33. Meanwhile I'll check with base 7.0.3
Also FYI, for me line no 660 points to field(PORT, $(PORT)) in ADBase.template file
Thanks
Sandeep
Get Outlook for Android<https://aka.ms/ghei36>
Sent: Friday, 21 February 2020, 6:36 pm
To: Sandeep Kumar Malu - UKRI STFC
Cc: tech-talk
Hi Sandeep, > The error I get on loading ADBase template is - > dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") > Error: syntax error > at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 > dbReadCOM: Parser stack dirty w/o error. 1 > Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. That is a strange error. Line 660 is a blank line at the end of ADBase.template. I am using asyn R4-38 and areaDetector R3-8 with no problems, and I think many others are as well. I notice that you are using base 7.0.2.2. I am using base 7.0.3.1. You said that you did not see the problem with areaDetector R3-5 and asyn R4-33. What version of base were you using with those versions of areaDetector and asyn? I would suggest updating base to 7.0.3.1 and see if the problem persists. Mark ________________________________ From: Tech-talk on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk Sent: Friday, February 21, 2020 6:11 AM To: [email protected] Subject: Areadetector error in version R3-8 Hi I recently upgrade EPICS base & support modules to latest versions which are as follows base - 7.0.2.2 seq - 2.2.6 asyn - 4-38 autosave - 5-9 astream - 2-6 busy -1-6 sscan - 2-10 areaDetector - 3-8 The error I get on loading ADBase template is - dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") Error: syntax error at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 dbReadCOM: Parser stack dirty w/o error. 1 Though If I comment these line in ADBase template, I can stream camera without any error # Set ASYN_TRACEIO_HEX bit by default record(asyn,"$(P)$(R)AsynIO") { field(PORT, $(PORT)) field(TIB2,"1") info("ADType", "ADDriver") } Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. Many Thanks Sandeep Malu
- RE: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
- Re: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
- RE: Areadetector error in version R3-8 Mark Rivers via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
