1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: error in 'make' during installation of areaDetector
To: 'Jong Woo Kim' <[email protected]>
Date: Wed, 26 Feb 2020 01:11:50 +0000
The errors you are getting are what I would expect if EPICS_BASE is not correctly defined.
Please double check that you have the path to EPICS_BASE correct in RELEASE_LIBS.local and RELEASE_PRODS.local.
Have you built EPICS_BASE successfully?
Sent: Tuesday, February 25, 2020 7:01 PM
Subject: Re: error in 'make' during installation of areaDetector
Hi Mark,
Thank you. Note that when I did 'git clone' for areaDetector under 'support', 'areaDetector' folder was created and ADCore, ADSupport and ADEiger were installed below it, not below areaDetector-R3-7.
In addition, I installed asyn4-37 under support.
The following is RELEASE_LIBS.local
____________________________________________
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# If using Debian packages then the following must be done:
#  SUPPORT should be defined to be the root location of any modules which should NOT come from the Debian package.
#  Any modules which should come from the Debian package should be commented out, except for EPICS_BASE.
#  For example to use a newer version of asyn and areaDetector then define ASYN, AREA_DETECTOR, ADCORE,
#  and ADSUPPORT here.  To use the Debian version of asyn then comment out ASYN here.
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=/usr/local/CXLS_SW/EPICS_NEW/synApps_6_1/support
# ASYN is needed for base classes
ASYN=$(SUPPORT)/asyn4-37
AREA_DETECTOR=$(SUPPORT)/areaDetector
# ADSupport is needed by ADCore plugins
ADSUPPORT=$(AREA_DETECTOR)/ADSupport
# ADCORE for base classes and plugins
ADCORE=$(AREA_DETECTOR)/ADCore
EPICS_BASE=/usr/local/CXLS_SW/EPICS_NEW/base-3.15.6
# If CONFIG_SITE.local defines WITH_PVA=YES and EPICS_BASE is prior to 7.0 then define the path here
# If using EPICS_BASE 7.0 or later the PVA files are in base itself and no additional definitions are needed.
#PVA=/corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
# PVA modules
# For versions prior to EPICS base 7.0 use this
#PVCOMMON=$(PVA)/pvCommonCPP
#PVACCESS=$(PVA)/pvAccessCPP
#PVDATA=$(PVA)/pvDataCPP
#PVDATABASE=$(PVA)/pvDatabaseCPP
#NORMATIVETYPES=$(PVA)/normativeTypesCPP
-include $(AREA_DETECTOR)/configure/RELEASE_LIBS.local.$(EPICS_HOST_ARCH)
_______________________________________________________________
The following is RELEASE_PRODS.local
#  and ADSUPPORT here, but comment out AUTOSAVE, BUSY, etc.
#AUTOSAVE is needed for save_restore
AUTOSAVE=$(SUPPORT)/autosave-R5-10
# BUSY is needed for busy record
BUSY=$(SUPPORT)/busy-R1-7-2
# CALC is needed for the sseq record that is used for the reset in NDStats.template
# and which is loaded into the example IOCs for general purpose use.
# CALC is also needed for scalcout record that SSCAN uses
CALC=$(SUPPORT)/calc-R3-7-3
# SNCSEQ is needed if CALC was built with SNCSEQ support (see CALC/configure/RELEASE)
SNCSEQ=$(SUPPORT)/seq-2-2-6
# SSCAN is needed for scanning threshold on Pilatus and general scanning.
# SSCAN also provides support needed for the swait record in CALC
SSCAN=$(SUPPORT)/sscan-R2-11-3
# Optional modules
# DEVIOCSTATS is used to monitor IOC resources
#DEVIOCSTATS=$(SUPPORT)/devIocStats-3-1-16
# ALIVE is used to send IOC status info to a central server
#ALIVE=$(SUPPORT)/alive-1-0-1
# ADPLUGINEDGE is optional plugin
#ADPLUGINEDGE=$(AREA_DETECTOR)/ADPluginEdge
# PVA modules
-include $(AREA_DETECTOR)/configure/RELEASE_PRODS.local.$(EPICS_HOST_ARCH)
This is outcomes of 'make'
[root@b support]# make clean uninstall
configure/CONFIG:18: /configure/CONFIG: No such file or directory
/bin/sh: /utils/depends.pl: No such file or directory
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/configure/RULES_TOP'.  Stop.
[root@b areaDetector]# make clean uninstall
configure/CONFIG:17: /configure/CONFIG: No such file or directory
Jong Woo
Sent: Tuesday, February 25, 2020 5:13 PM
To: Jong Woo Kim <[email protected]>
Hi Jong Woo,
Ø  After modification of configure files, I ran 'make'. But the following message came out.
Did you modify the following files in areaDetector/configure:
RELEASE_LIBS.local (to set paths to base, SUPPORT, asyn, etc.)
RELEASE_PRODS.local (to set paths to base, SUPPORT, asyn, etc.)
CONFIG_SITE.local (to change build options)
RELEASE.local (to control what gets built)
What directory were you in when you typed “make”?  You should be in the top-level areaDetector directory.
Please send the complete output of “make” and your RELEASE_LIBS.local and RELEASE_PRODS.local files.
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Tuesday, February 25, 2020 6:01 PM
To: [email protected]
Subject: error in 'make' during installation of areaDetector
Hello,
Via 'git clone', I installed 'areaDetector' under [synApps_6_1/support], and 'ADCore', 'ADsupport' and 'ADEiger' below it.
It would be appreciated, if you give me a feedback.
Best,
Jong Woo
Re: error in 'make' during installation of areaDetector Mark Rivers via Tech-talk
error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
RE: error in 'make' during installation of areaDetector Mark Rivers via Tech-talk
Re: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Prev: Re: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Next: Re: error in 'make' during installation of areaDetector Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
