Subject: NORD on a char waveform record
From: Thomas Willemsen - UKRI STFC via Tech-talk <[email protected]>
Date: Tue, 3 Mar 2020 13:05:50 +0000
We have recently updated several support modules, including streamdevice, and have noticed the following change in behaviour:
We have a device whose stream device protocol file looks like:
    InTerminator = CR;
    OutTerminator = CR;
    get_MEASUREMENTS {
        out "MM,1111111111111111";
        in "MM,1111111111111111%s";
Linked to a record that looks like:
    record(waveform, "$(P)STATUS:RAW")
        field(DTYP, "stream")
        field(FTVL, "CHAR")
        field(NELM, "512")
        field(INP, "@kynctm3k.proto get_MEASUREMENTS $(PORT)")
        field(SCAN, "1 second")
The messages to and from the device look as follows:
    2020/03/03 11:55:09.948 localhost:52209 write 20
    MM,1111111111111111\r
    2020/03/03 11:55:09.951 localhost:52209 read 164
    MM,1111111111111111,+FFFFFFF,+004.000,-FFFFFFF,+008.000,-FFFFFFF,+012.000,+FFFFFFF,+016.000,+FFFFFFF,+020.000,-FFFFFFF,+024.000,+FFFFFFF,+028.000,-FFFFFFF,+032.000\r
Under streamdevice 2.5.10, this sets the NORD field of the waveform to 144. Under streamdevice 2.8.10, the NORD field is set to 145 - but
the actual string is unchanged, suggesting that the NULL terminator may now be being included in the NORD count. Unfortunately this broke
one of our drivers, which checked the length of the response before doing some processing.
What is the expected behaviour here - in general should NORD on a char waveform be including the NULL terminator or not?
Tom
Prev: FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Next: Re: NORD on a char waveform record Mark Rivers via Tech-talk
Prev: RE: EPICS on windows10 Debian Shell Freddie Akeroyd - UKRI STFC via Tech-talk
