Subject: RE: EPICS on windows10 Debian Shell
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
Date: Tue, 3 Mar 2020 15:19:47 +0000
Would it be possible to do this check at run time rather than compile time - maybe look for a "WSL_DISTRO_NAME" or "WSLENV" environment variable and set a global flag? A non-WSL compiled EPICS program could be run under WSL, this would not be caught by a compile time check. This problem might be fixed in WSL 2 though, so a WSL version check may be required at some point too.
Freddie
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Alfio Rizzo via Tech-talk
Sent: 03 March 2020 09:46
To: [email protected]
Subject: FW: EPICS on windows10 Debian Shell
When I compile epics base on a WSL Debian/Ubunt shell So far I manually commented out (when needed) the _WIN32 macro in the  blockingUDPTransport.cpp file
But a possible clean solution is to create a macro called WSL , checking the kernel version (my kernel is for instance 4.4.0-17763-Microsoft )
ifeq ($(findstring Microsoft,$(shell uname -r)),Microsoft)
CPPFLAGS += -D_WSL_
Endif
Those lines can be put in the RULES_BUILD file of EPICS Base for instance,
Then this macro can be used in the  blockingUDPTransport.cpp file (see attachment)
It could be possible to apply that in the next EPICS base release patch ?
Thanks
Best
Alfio
Sent: Wednesday, October 2, 2019 6:36 AM
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Hi
The macros are defined the same as any GCC Linux/Unix compiler, I have already checked this before.
See file in attachment
Best
Alfio
Sent: Wednesday, October 2, 2019 2:22 AM
To: Alfio Rizzo <[email protected]>
Subject: Re: EPICS on windows10 Debian Shell
On 10/1/19 8:55 AM, Alfio Rizzo via Tech-talk wrote:
> As it should be, the OS macro is defined as __linux__ not as _WIN32,
> since the compiler is NOT MinGW or CYGWIN, but GNU as I said before.
> So, then it comes issue I had was this UDP socket biding issue,
> since binding is still handled a la Windows.
> So the problem is in the source file blockingUDPTransport.cpp
> where the macro _WIN32 is not used consistently in my case.
Can you check what macros this compiler pre-defines?
My usual reference doesn't cover this new variation.
https://sourceforge.net/p/predef/wiki/Home/
> cpp -dM /dev/null > wsl_predefined.h
FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Prev: Re: NORD on a char waveform record Mark Rivers via Tech-talk
Next: Re: NORD on a char waveform record Mark Rivers via Tech-talk
Prev: FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Next: NORD on a char waveform record Thomas Willemsen - UKRI STFC via Tech-talk
