There is already a plugin that uses OpenCV. You may be able to use that directly, or use it as a starting point.
https://github.com/areaDetector/ADCompVision
From: Tech-talk <[email protected]> on behalf of Marcin Lukaszewski via Tech-talk <[email protected]>
Sent: Wednesday, March 4, 2020 9:59 AM
To: [email protected]
Subject: Problem during compilation of IOC with custom ADPlugin
Hi all,
I'm working on custom ADPlugin with OpenCV.
I use ADPluginBar as a reference, following instructions from https://github.com/areaDetector/ADPluginBar
I made required changes to the areaDetector installation and both ADPluginBar and my plugin compiles successfully with areaDetector.
However, when I try to compile IOC with ADPluginBar, I get undefined reference errors, like:
/usr/local/epics/support/areaDetector/areaDetector-R3-8/ADPluginBar/lib/linux-x86_64/libNDPluginBar.so: undefined reference to `cv::Mat::deallocate()
I assume that in my IOC I need to link only ADPluginBar and there is no need to directly link external libraries (OpenCV and zbar). Is that correct?
What I'm missing?
Has anyone have an example of IOC with ADPluginBar or custom ADPlugin which uses external library, like OpenCV?
My environment:
base: 7.0.3.1
asyn: 4-38
areaDetector: R3-8
OpenCV: 2.4.13.6 (installed from the source, to the default system location)
I appreciate any suggestion or feedback.
Thanks
Marcin
- Re: Problem during compilation of IOC with custom ADPlugin Wlodek, Jakub via Tech-talk
- Problem during compilation of IOC with custom ADPlugin Marcin Lukaszewski via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
