1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Problem during compilation of IOC with custom ADPlugin
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: Mark Rivers via Tech-talk <[email protected]>, Marcin Lukaszewski <[email protected]>
Date: Wed, 4 Mar 2020 16:48:24 +0000
Hi Marcin,
As Mark said, ADCompVision is a plugin that uses OpenCV more thoroughly than ADPluginBar, and may be a better starting point.
For the errors, if you are using OpenCV from a system location, make sure to comment out OPENCV_LIB and OPENCV_INCLUDE definitions in
CONFIG_SITE.* files. If these are defined and linking to system libraries you may run into such undefined reference errors.
Best,
Jakub
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Wednesday, March 4, 2020 11:19 AM
To: Marcin Lukaszewski <[email protected]>
There is already a plugin that uses OpenCV.  You may be able to use that directly, or use it as a starting point.
https://github.com/areaDetector/ADCompVision
From: Tech-talk <[email protected]> on behalf of Marcin Lukaszewski via Tech-talk <[email protected]>
Sent: Wednesday, March 4, 2020 9:59 AM
To: [email protected]
Subject: Problem during compilation of IOC with custom ADPlugin
Hi all,
I'm working on custom ADPlugin with OpenCV.
I use ADPluginBar as a reference, following instructions from https://github.com/areaDetector/ADPluginBar
I made required changes to the areaDetector installation and both ADPluginBar and my plugin compiles successfully with areaDetector.
However, when I try to compile IOC with ADPluginBar, I get undefined reference errors, like:
/usr/local/epics/support/areaDetector/areaDetector-R3-8/ADPluginBar/lib/linux-x86_64/libNDPluginBar.so: undefined reference to `cv::Mat::deallocate()
I assume that in my IOC I need to link only ADPluginBar and there is no need to directly link external libraries (OpenCV and zbar). Is that correct?
What I'm missing?
Has anyone have an example of IOC with ADPluginBar or custom ADPlugin which uses external library, like OpenCV?
My environment:
base: 7.0.3.1
asyn: 4-38
areaDetector: R3-8
OpenCV: 2.4.13.6 (installed from the source, to the default system location)
I appreciate any suggestion or feedback.
Thanks
Marcin
Problem during compilation of IOC with custom ADPlugin Marcin Lukaszewski via Tech-talk
Re: Problem during compilation of IOC with custom ADPlugin Mark Rivers via Tech-talk
Prev: Re: Problem during compilation of IOC with custom ADPlugin Mark Rivers via Tech-talk
Next: String size limit for Eiger FileWriter when compiling with g++ > 5.2 Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Problem during compilation of IOC with custom ADPlugin Gofron, Kazimierz via Tech-talk
