Subject: Re: CA output links not working with PINI=YES?
From: Christoph Schroeder via Tech-talk <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 5 Mar 2020 16:22:31 +0100
Hi Lewis,
yep that seems to be the same problem. I read this thread and there were
some suggestions, but it seem that none of them made it into a real feature.
Did you find an elegant workaround? I created a rather dirty solution
with a seq record using the DLY field.
Best regards,
Christoph
On 3/5/20 2:07 PM, J. Lewis Muir wrote:
On 03/05, Christoph Schroeder via Tech-talk wrote:
Processing TEST:longout afterwards will work as intended. Am I missing
something or do CA output links do not work on initialization in general?
I tested this with base R3.15.5 and base R7.0.2.1 whith two IOCs running
on the same machine, same behavior for both.
Maybe the CA link hasn't finished connecting yet?
See this thread:
   https://epics.anl.gov/tech-talk/2012/msg02082.php
Lewis
(bb|[^b]{2})
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Prev: Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Next: Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
