Subject: Re: CA output links not working with PINI=YES?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Christoph Schroeder <[email protected]>
Date: Thu, 5 Mar 2020 09:34:42 -0600
On 03/05, Christoph Schroeder wrote:
> yep that seems to be the same problem. I read this thread and there were
> some suggestions, but it seem that none of them made it into a real feature.
> Did you find an elegant workaround? I created a rather dirty solution
> with a seq record using the DLY field.
I don't think so, but I can't remember for sure.  I probably added an
epicsThreadSleep, changed the links to not be CA links, or restructured
the record instances to work around the problem.
Lewis
Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Prev: Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Next: Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
