1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SIOL field buffer size?
From: Benjamin Franksen via Tech-talk <[email protected]>
Date: Thu, 5 Mar 2020 19:49:02 +0100
Am 05.03.20 um 17:58 schrieb Daykin, Evan via Tech-talk:
> Is it correct that SIOL only holds 40 characters, or is this merely
> a cosmetic trait when the value is pulled from channel access?
The latter. Link fields no longer have this limit (or a much larger
one). But the DBR_STRING request type in CA has a fixed maximum number
of bytes. However, I believe you can nowadays (>= 3.15) use a trailing
'$' in the PV name to make CA use DBR_CHAR with the correct number of
elements.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: SIOL field buffer size? Ralph Lange via Tech-talk
SIOL field buffer size? Daykin, Evan via Tech-talk
Prev: write to a single element of an array field Benjamin Franksen via Tech-talk
Next: Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: SIOL field buffer size? Daykin, Evan via Tech-talk
Next: Re: SIOL field buffer size? Ralph Lange via Tech-talk
