1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: SIOL field buffer size?
From: "Daykin, Evan via Tech-talk" <[email protected]>
Date: Thu, 5 Mar 2020 16:58:53 +0000
I am trying to run some tests using the simulation mode utility of ai/ao records, using base version 3.15.7. I noticed that my SIOL fields are getting cut off for the record under test.
I intend to define SIOL for my record as follows:
VSRC_SIM_RF:RFC_N0001:PHA_CSET_DDZN_HW CP MS
What I get back from channel access is:
VSRC_SIM_RF:RFC_N0001:PHA_CSET_DDZN_HW #<-Trailing space
Is it correct that SIOL only holds 40 characters, or is this merely a cosmetic trait when the value is pulled from channel access? It wasn’t entirely clear upon a cursory glance at epics-base.
-Evan
Re: SIOL field buffer size? Benjamin Franksen via Tech-talk
Prev: Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
Next: Re: CA output links not working with PINI=YES? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
Next: Re: SIOL field buffer size? Benjamin Franksen via Tech-talk
