Hi Ben,
On Mar 5, 2020, at 12:16 PM, Benjamin Franksen via Tech-talk < [email protected]> wrote:
What we want to do here is write a string to an input link field once at
init time. Link fields can be written to only via CA, which is why we
have to use a CA link.
Do you have to wait until after iocInit to set the value of that input link field? If you could do it beforehand you could load a separate .db file that just sets the link field of that record. You can also use the IOC’s ‘dbpf’ command to write
to a link field in your startup script, and the length of that string isn’t limited to 40 characters any more.
Christoph’s original example doesn’t show him writing to a link field, and I’m still a little confused exactly what you’re trying to do. Given the actual complexity of what you’re trying to do (as against the apparent simplicity that you’re wanting)
I suspect using a sequence program might be simpler, but more detail of the actual problem might allow us to find a simpler solution.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: CA output links not working with PINI=YES? Mooney, Tim M. via Tech-talk
- Re: CA output links not working with PINI=YES? Benjamin Franksen via Tech-talk
- CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
- Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
- Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
- Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
Re: SIOL field buffer size? Benjamin Franksen via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
