Hi Andrew
may I piggyback on this question? I got another documentation related question.
Some time ago I tried to use JSON input links, but failed w/ anything but pva.
DB example is below, based on this doc https://epics.anl.gov/base/R7-0/3-docs/links.html
record(ai, "${SYS}:constFloatPi") {
field(INP, 3.14159265358979)
field(PREC, 9)
field(PINI, "NO")
field(DESC, "ai, holding Pi, PINI=0")
# db input link
# not working: error --> dbJLinkInit: Link type 'db' not found
record(ai, "${SYS}:dbInput") {
field(INP, {db:"${SYS}:constFloatPi"})
Can you please point out were the current documentation of the JSON link feature can be found? Or comment on the error "Link type 'db' not found" I receive?
best
Niko
Paul Scherrer Institute
Dr. Niko Kivel
Forschungsstrasse 111
WBGB/017
5232 Villigen PSI
Switzerland
phone: +41 56 310 2226
email:
[email protected]
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Sent: Wednesday, March 25, 2020 21:49
To: Rolf Keitel
Cc: EPICS tech-talk
Subject: Re: PV Access
Hi Rolf,
HTH,
- Andrew
I am looking for an introductory document which teaches me how to create an IOC database with structured data for PV Access.
Looks like I am too blind to find it.
Thanks – rolf -
Rolf Keitel, Ph.D
TRIUMF, 4004 Wesbrook Mall
Vancouver, BC, V6T 2A3
Tel.: 604 222 7453
-- The old generation has to die off so that a new set of idiots can make the same mistakes all over again --
Complexity comes for free, simplicity you have to work for.
