1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PV Access
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 26 Mar 2020 07:09:36 +0100
Hi Niko,
The key is the second sentence in the documentation you refer to:
The IOC continues to support the older link types that do not use JSON to specify their link addresses.
Cheers,
~Ralph
On Wed, 25 Mar 2020 at 23:33, Kivel Niko (PSI) via Tech-talk <[email protected]> wrote:
Hi Andrew
may I piggyback on this question? I got another documentation related question.
Some time ago I tried to use JSON input links, but failed w/ anything but pva.
DB example is below, based on this doc https://epics.anl.gov/base/R7-0/3-docs/links.html
record(ai, "${SYS}:constFloatPi") {
  field(INP,  3.14159265358979)
  field(PREC, 9)
  field(PINI, "NO")
  field(DESC, "ai, holding Pi, PINI=0")
# db input link
# not working: error --> dbJLinkInit: Link type 'db' not found
record(ai, "${SYS}:dbInput") {
  field(INP, {db:"${SYS}:constFloatPi"})
Can you please point out were the current documentation of the JSON link feature can be found? Or comment on the error "Link type 'db' not found" I receive?
Re: PV Access Ben Franksen via Tech-talk
PV Access Rolf Keitel via Tech-talk
Re: PV Access Johnson, Andrew N. via Tech-talk
Re: PV Access Kivel Niko (PSI) via Tech-talk
Prev: Re: PV Access Kivel Niko (PSI) via Tech-talk
Next: Re: PV Access Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
