1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PV Access
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 26 Mar 2020 09:22:45 +0100
Am 26.03.20 um 07:09 schrieb Ralph Lange via Tech-talk:
>> # not working: error --> dbJLinkInit: Link type 'db' not found
>> record(ai, "${SYS}:dbInput") {
>>   field(INP, {db:"${SYS}:constFloatPi"})
> The key is the second sentence in the documentation you refer to:
> The IOC continues to support the older link types that do not use JSON to
> specify their link addresses.
Hi Ralph,
I think your answer, while not exactly wrong, is a bit cryptic, so let
me explain.
The docs list the available link JSON types. There is no "db" link type
listed, which explains the error you get. What Ralph alluded to is the
reason /why/ there is no JSON "db" link type. This is because, strange
as it may sound, '{db:"${SYS}:constFloatPi"}' is actually a valid name
for a record and thus for a PV. A long, long time ago it was decided
that a PV name may contain any byte that is not reserved for a special
purpose by EPICS base (such as '.' and a few others), instead of a
priori limiting this set to something reasonable.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: pEpkey.asc
Description: application/pgp-keys
Re: PV Access Ben Franksen via Tech-talk
Re: PV Access Kivel Niko (PSI) via Tech-talk
PV Access Rolf Keitel via Tech-talk
Re: PV Access Johnson, Andrew N. via Tech-talk
Re: PV Access Ralph Lange via Tech-talk
Prev: Re: PV Access Ralph Lange via Tech-talk
Next: Re: PV Access Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
