1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Filtering messages print on the IOC shell console
To: "'Konrad, Martin'" <[email protected]>, "J. Lewis Muir" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 27 Mar 2020 14:27:18 +0000
Hi Martin,
> dbLoadTemplate.y is printing messages using fprintf(stderr,...);
> My recommendation would be to print all messages to the same stream.
Unfortunately this is out of my control.  The problem I am seeing is the garbling of output from dbLoadTemplate (EPICS base) and the echoing of subsequent vxWorks shell commands (Wind River).
But this suggests that the vxWorks shell is proceeding to execute the next command before the previous one has displayed all of its output on the console?  This does not seem correct.
Note that in my previous post I was using procServ for the telnet connection to this IOC through a terminal server, so perhaps procServ was the problem.  I took procServ out of the loop and I see the same thing:
# Initialize Systran DAC
# initDAC128V(char *portName, int carrier, int slot)
# portName  = name to give this asyn port
# carrier     = IPAC carrier number (0, 1, etc.)
# slot        = IPAC slot (0,1,2,3, etc.)
initDAC128V("DAC1", 0, 3)
value = 0 = 0x0
dbLoadTemplate "DAC.template"
filename="../dbStatic/dbLevalue = xRoutines.c"0 line number=264
S_ = nfsLib_NFSERR_NOE0xNT dbRead opening 0
file /corvet Acromag IP-330 ADC
/dac128/epics/devel# initIp330(
db2-9/db/singleDAC.#   const char *portName, int carrier, int slot,
filename="../d *typeString, const char *rangeString,
es.c" l/dbLexRoutin#   int firstChan, int lastChan,
ine number=264
sLib#   int intVec)
d opening file /Rea# portName    = name to give this asyn port
/devel/dac1me/epics# carrier     = IPAC carrier number (0, 1, etc.)
C.db2-9/db/singleDA# slot        = IPAC slot (0,1,2,3, etc.)
filename="..  = "D" or "S" for differential or single-ended
ines.c"ic/dbLexRout# rangeString = "-5to5","-10to10","0to5", or "0to10"
 line number=264
nfsLib_NFSERR_NO  This value must match hardware setting selected
file bRead opening # firstChan   = first channel to be digitized.  This must be in the range:
scorvette/home/epic#               0 to 31 (single-ended)
ddevel/dac128V-2-9/#               0 to 15 (differential)
b/singleDAC.db
filename="../dbStatt channel to be digitized
 line nxRoutines.c"# intVec        Interrupt vector
umber=264
NFSERR_NOENT dp330("Ip330_1",0,2,"D","-5to5",0,15,120)
value = 0 = 0x0
Note that if I fix the problem with the missing singleDAC.db file then the output is fine:
value = 0 = 0x0
value = 0 = 0x0
# Initialize Acromag IP-330 ADC
# initIp330(
#   const char *typeString, const char *rangeString,
#   int intVec)
# typeString  = "D" or "S" for differential or single-ended
#               This value must match hardware setting selected
# lastChan    = last channel to be digitized
initIp330("Ip330_1",0,2,"D","-5to5",0,15,120)
value = 0 = 0x0
So the problem is that dbLoadTemplate error messages are still coming out when the vxWorks shell has proceeded to process the next comments and commands in the file.
Is this how it should work?
-----Original Message-----
Sent: Friday, March 27, 2020 9:09 AM
To: Mark Rivers <[email protected]>; J. Lewis Muir <[email protected]>; Johnson, Andrew N. <[email protected]>
Subject: Re: Filtering messages print on the IOC shell console
Hi Mark,
> Here is an example of garbled output coming simply from the
> dbLoadTemplate command.
> Is this because dbLoadTemplate is actually loading the database file
> in another thread?  If not why is it garbled?
Other parts of the code are probably printing to stdout. AFAIK POSIX doesn't give any guarantees regarding the ordering of messages printed to stdout vs. stderr. The following example demonstrates the problem:
#include <stdio.h>
int main() {
printf("AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA");
  fprintf(stderr,
"BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB");
On my Linux machine I get the following output:
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBAAAAA
This suggests that my OS is using a 1024 byte buffer. Other operating systems might use different buffer sizes. I'm not sure if the behavior is specified when the messages are terminated with a linebreak.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
RE: Filtering messages print on the IOC shell console Freddie Akeroyd - UKRI STFC via Tech-talk
Filtering messages print on the IOC shell console Paduan Donadio, Marcio via Tech-talk
Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Re: Filtering messages print on the IOC shell console Konrad, Martin via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console Konrad, Martin via Tech-talk
Next: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
