1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Filtering messages print on the IOC shell console
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Konrad, Martin" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 27 Mar 2020 10:28:27 -0500
On 03/27, Konrad, Martin wrote:
> My recommendation would be to print all messages to the same stream.
I suppose some other options could be:
1. Disable stdout and stderr buffering on the IOC console.
2. Add an fflush call after any legitimate printf/fprintf in EPICS and
   EPICS-related code.
3. Add special console_{printf,fprintf} functions (or whatever they
   should be named) that will do the printf/fprintf, and then do an
   fflush.  Then say that all code that would have used printf/fprintf
   should use these instead.
4. A thread-safe option (If the only callers of printf/fprintf are
   guaranteed to be running in a single-process/single-threaded context,
   then this is unnecessary): Add special console_{printf,fprintf}
   functions (or whatever they should be named) that are thread-safe
   (i.e., can be called concurrently from two or more processes or
   threads) that will acquire a console mutex (or whatever it should
   be named), do the printf/fprintf, and then do an fflush.  Then say
   that all code that would have used printf/fprintf should use these
   instead.
5. Come up with another logging mechanism for the legitimate uses of
   printf/fprintf that is like the errlog facility and will guarantee
   that output will not be garbled, but that should be used instead
   of printf/fprintf for the cases where using the errlog facility is
   considered inappropriate.  Then say that all code that would have
   used printf/fprintf should use these instead.
Lewis
Filtering messages print on the IOC shell console Paduan Donadio, Marcio via Tech-talk
Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Re: Filtering messages print on the IOC shell console Konrad, Martin via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Next: RE: Filtering messages print on the IOC shell console Freddie Akeroyd - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Newport DL325 Igor Kriznar via Tech-talk
