1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Home motorSim Device
To: William Cork <[email protected]>
Date: Fri, 10 Apr 2020 16:44:22 +0000
Hi Will,
I don't know the state of Kunal's repository that you referenced.  I think the more "official" simulated motor repository is this one:
https://github.com/epics-motor/motorMotorSim
There are actually 2 drivers in that source code, a "Model 2" driver (drvMotorSim.c) and a new "Model 3" driver (motorSimDriver.cpp).  I recommend only using motorSimDriver.cpp since that is the current standard framework.
The example IOC loads 8 motors.  The first 4 are the old Model 2 driver, and the last 4 are the new Model 3 driver.
I just tested homing with both drivers.
With the Model 2 driver when the homing is complete MSTA is 0xa.  This is bits 1 and 3 which mean
        unsigned int RA_HOME        :1; /* The home signal is on */
        unsigned int RA_DONE        :1; /* a motion is complete */
With the Model 3 driver when the homing is complete the MSTA is 0x82.  This is bits 1 and 7 which mean
        unsigned int EA_HOME        :1; /* encoder home signal on */
So one driver sets RA_HOME (not encoder home) while the other set EA_HOME (encoder home).
Note that neither of them set bit 14 which is
  unsigned int RA_HOMED       :1; /* Axis has been homed.*/
This is probably an bug in these drivers, they should be setting that bit as well.
From: Tech-talk <[email protected]> on behalf of William Cork via Tech-talk <[email protected]>
Sent: Friday, April 10, 2020 10:25 AM
To: [email protected]
Subject: Home motorSim Device
Playing around with the motor and asyn modules to get more familiar with EPICS motion control.
I'm using an example motorSim found here: https://github.com/shroffk/motorsim.git
Using:
asyn-R4-37
motor-R7-1
calc-R3-7-3
Having an issue where I tell an sioc using motorSim to home but, the MSTA record never updates the HOMED bit.
Startup deck has these lines to configure motorSim device:
motorSimCreate( 0, 0, -32000, 32000, 0, 1, 6 )
drvAsynMotorConfigure("motorSim1", "motorSim", 0, 6)
fakemotor.db:
record(ao, "$(Sys)$(Dev)-SP") {
    field(FLNK, "$(Sys)$(Dev)-SP_")
record(seq, "$(Sys)$(Dev)-SP_") {
    #disable mtr rec processing
    field(DOL1, "1")
    field(LNK1, "$(Mtr).DISA")
    # write setpoint to mtr rec
    field(DLY2, "0.1")
    field(DOL2, "$(Sys)$(Dev)-SP")
    field(LNK2, "$(Mtr).VAL CP")
    # to re-enable mtr rec processing, write or process "$(Sys)$(Dev)Cmd:Go-Cmd"
record(ai, "$(Sys)$(Dev)-I") {
    field(INP, "$(Mtr).RBV CPP")
record(bo, "$(Sys)$(Dev)Cmd:Go-Cmd") {
    field(DOL, "0")
    field(OUT, "$(Mtr).DISA CPP")
record(bo, "$(Sys)$(Dev)Cmd:Stop-Cmd") {
    field(VAL, "1")
    field(OUT, "$(Mtr).STOP CPP")
record(bi, "$(Sys)$(Dev)Sts:Moving-Sts") {
    field(INP, "$(Mtr).DMOV CPP")
    field(ZNAM, "Moving")
    field(ONAM, "Done")
Does motorSim have support for homing?
Is it broken from the seq record in fakemotor.db?
Your help is appreciated,
Will
Re: Home motorSim Device William Cork via Tech-talk
Re: Home motorSim Device Peterson, Kevin M. via Tech-talk
Prev: Home motorSim Device William Cork via Tech-talk
Next: RE: Filtering messages print on the IOC shell console Freddie Akeroyd - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Home motorSim Device William Cork via Tech-talk
