Playing around with the motor and asyn modules to get more familiar with EPICS motion control.
I'm using an example motorSim found here: https://github.com/shroffk/motorsim.git Using: asyn-R4-37 motor-R7-1 calc-R3-7-3 Having an issue where I tell an sioc using motorSim to home but, the MSTA record never updates the HOMED bit. Startup deck has these lines to configure motorSim device: ``` motorSimCreate( 0, 0, -32000, 32000, 0, 1, 6 ) drvAsynMotorConfigure("motorSim1", "motorSim", 0, 6) ``` fakemotor.db: ``` record(ao, "$(Sys)$(Dev)-SP") { field(FLNK, "$(Sys)$(Dev)-SP_") } record(seq, "$(Sys)$(Dev)-SP_") { #disable mtr rec processing field(DOL1, "1") field(LNK1, "$(Mtr).DISA") # write setpoint to mtr rec field(DLY2, "0.1") field(DOL2, "$(Sys)$(Dev)-SP") field(LNK2, "$(Mtr).VAL CP") # to re-enable mtr rec processing, write or process "$(Sys)$(Dev)Cmd:Go-Cmd" } record(ai, "$(Sys)$(Dev)-I") { field(INP, "$(Mtr).RBV CPP") } record(bo, "$(Sys)$(Dev)Cmd:Go-Cmd") { field(DOL, "0") field(OUT, "$(Mtr).DISA CPP") } record(bo, "$(Sys)$(Dev)Cmd:Stop-Cmd") { field(VAL, "1") field(OUT, "$(Mtr).STOP CPP") } record(bi, "$(Sys)$(Dev)Sts:Moving-Sts") { field(INP, "$(Mtr).DMOV CPP") field(ZNAM, "Moving") field(ONAM, "Done") } ``` Does motorSim have support for homing? Is it broken from the seq record in fakemotor.db? Your help is appreciated, Will
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
