1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Home motorSim Device
From: William Cork via Tech-talk <[email protected]>
To: "Peterson, Kevin M." <[email protected]>
Date: Fri, 10 Apr 2020 17:00:05 -0700
Hi Kevin,
I added a PR to the motorMotorSim issue that solves that issue:
-Will
On Fri, Apr 10, 2020 at 12:53 PM Peterson, Kevin M. <[email protected]> wrote:
I created a github issue for this:
   https://github.com/epics-motor/motorMotorSim/issues/1
Kevin
On 4/10/20 11:44 AM, Mark Rivers via Tech-talk wrote:
> Hi Will,
> I don't know the state of Kunal's repository that you referenced.  I think the more "official" simulated motor repository is this one:
> There are actually 2 drivers in that source code, a "Model 2" driver (drvMotorSim.c) and a new "Model 3" driver (motorSimDriver.cpp).  I recommend only using motorSimDriver.cpp since that is the current standard framework.
> The example IOC loads 8 motors.  The first 4 are the old Model 2 driver, and the last 4 are the new Model 3 driver.
> I just tested homing with both drivers.
> With the Model 2 driver when the homing is complete MSTA is 0xa.  This is bits 1 and 3 which mean
>          unsigned int RA_HOME        :1; /* The home signal is on */
>          unsigned int RA_DONE        :1; /* a motion is complete */
> With the Model 3 driver when the homing is complete the MSTA is 0x82.  This is bits 1 and 7 which mean
>          unsigned int EA_HOME        :1; /* encoder home signal on */
> So one driver sets RA_HOME (not encoder home) while the other set EA_HOME (encoder home).
> Note that neither of them set bit 14 which is
>    unsigned int RA_HOMED       :1; /* Axis has been homed.*/
> This is probably an bug in these drivers, they should be setting that bit as well.
> Mark
Re: Home motorSim Device Peterson, Kevin M. via Tech-talk
Home motorSim Device William Cork via Tech-talk
Re: Home motorSim Device Mark Rivers via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Next: enable PV searching only over TCP 黄佳伟 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Home motorSim Device Peterson, Kevin M. via Tech-talk
Next: Re: Home motorSim Device Peterson, Kevin M. via Tech-talk
