Subject: Re: anyone ever crosscompile pvaPy?
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 22 May 2020 18:46:57 +0000
On 5/22/20 12:10 PM, Peter Milne wrote:
> Hi Andrew
> On 22/05/2020 16:27, Johnson, Andrew N. wrote:
>> Hi Peter,
>> On May 22, 2020, at 3:23 AM, Peter Milne via Tech-talk
>> <[email protected]<mailto:[email protected]>> wrote:
>> We have a requirement to run pvaPy on a linux-arm system.
>> The ARM system is configured to provide a full EPICS7, Boost lib.
>> Following
>> https://github.com/epics-base/pvaPy/blob/master/README.md
>> Custom Build:
>> Seems to build fine for EPICS_HOST_ARCH=linux-x86_64
>> It's also putting in hooks for linux-arm:
>> ls ./src/pvaccess/O.linux-arm
>> Makefile
>> pgm TOP ../../.. T_A linux-arm
>> make[3]: Nothing to be done for 'install'.
>> make[3]: Leaving directory
>> '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-arm'
>> make[2]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess'
>> make[1]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src'
>> .... does nothing..
>> Is there any way to enable a cross-compile?
>> I don't see any PROD_HOST entries that could be changed to PROD, for
>> example.
>> The important entry in src/pvaccess/Makefile is the line
>> LOADABLE_LIBRARY_HOST += pvaccess
>> Since pvaPy is a dynamic library that gets loaded by Python, there
>> are no binaries to create so no use of the PROD or PROD_HOST
>> variables in the Makefile. Change the above to LOADABLE_LIBRARY and
>> it should start cross-compiling for your target.
> Yes, that's it!. Thank you. And, really generically the same idea as
> PROD_HOST, should have spotted that.
> So, the good news, it's trying to build.
> The bad news, there are errors, maybe just one:
> /usr/include/python3.7m/pyconfig.h:4:10: fatal error: pyconfig-32.h:
> So the next step is to get it to look at the linux-arm version of the
> python headers rather than the HOST version..
> ... and that suddenly becomes really site-specific..
The build looks into configure/CONFIG_SITE.local file to determine any
site specific settings, which might also include a custom python build.
Specifically, variables that can be modified are PVA_PY_CPPFLAGS and
PVA_PY_LDFLAGS. In one of my builds I have the following:
bluegill2> more configure/CONFIG_SITE.local
PVA_PY_CPPFLAGS = -I/local/sveseli/MARTY/CONDA/include/python3.7m
-I/local/sveseli/MARTY/opt/boost-python-1.70.0/include
PVA_PY_LDFLAGS = -L/local/sveseli/MARTY/CONDA/lib
-L/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64 -lpython3.7m
PVA_PY_SYS_LIBS = boost_python37  boost_numpy37
PVA_API_VERSION = 482
PVA_RPC_API_VERSION = 482
HAVE_BOOST_NUM_PY = 0
HAVE_BOOST_PYTHON_NUM_PY = 1
PYTHON_VERSION = 3.7
PVA_PY_PYTHON = /local/sveseli/MARTY/CONDA/bin/python3
PVA_PY_PYTHONPATH =
/local/sveseli/MARTY/pvapy-sv/lib/python/3.7/linux-x86_64
PVA_PY_LD_LIBRARY_PATH =
/local/sveseli/MARTY/CONDA/lib:/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64
PVA_PY_SPHINX_BUILD = /local/sveseli/MARTY/CONDA/bin/sphinx-build
PVA_PY_EPICS_BASE = /local/sveseli/MARTY/opt/epics-7.0.3.1
PVA_PY_EPICS4_DIR = /local/sveseli/MARTY/opt/epics-7.0.3.1
PVA_PY_HOST_ARCH = linux-x86_64
PVA_PY_SETUP_SH =
/local/sveseli/MARTY/pvapy-sv/bin/linux-x86_64/pvapy_setup_full.3.7.sh
Automatic configuration should work for the host architecture that you
are building on, but at the moment it will likely not work for
cross-compiles.
>> Hopefully you and Sinisa can work out some way to adjust the build so
>> cross-builds like this can be configured more easily, but I suspect
>> it may always need some kind of manual configuration to enable it.
> .. as confirmed above.
> Should be possible to make a configure/ option of course..
> Thanks again Andrew
> Cheers
I talked to Andrew about making this easier.
Sinisa
> Peter
>> - Andrew
>> Complexity comes for free, simplicity you have to work for.
Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Re: anyone ever crosscompile pvaPy? Johnson, Andrew N. via Tech-talk
Prev: Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Next: Reminder: Codeathon Survey Johnson, Andrew N. via Tech-talk
Next: Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
