Subject: Re: anyone ever crosscompile pvaPy?
From: Peter Milne via Tech-talk <[email protected]>
To: "Veseli, Sinisa" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 23 May 2020 23:36:55 +0100
Hi Sinisa
Thank you very much for your help as well as Andrew.
Reporting Success!: the server/client example pair works.
Method repeated below for reference (builds HOST and TARGET).
For general use, the key is to introduce $(T_A) HEADER and LIB search paths that are valid for the
cross compile to work. Also, I had to set HAVE_BOOST_PYTHON_NUM_PY = 0, surprised as not in the make config
If we can automate this with a template for "make configure" rather than hacking
the generated file configure/CONFIG_SITE.local, it would be better.
Best regards
Peter
Our embedded system uses buildroot, so that influences where to look for embedded headers and libs.
Proceeded as follows:
make configure EPICS_BASE=$HOME/PROJECTS/EPICS/base \
   EPICS4_DIR=$HOME/PROJECTS/EPICS/base PYTHON_VERSION=3
Modified CONFIG_SITE.local as follows.
pgm@staffa3 pvaPy]$ git diff 5048ae703c1ae1b5bd5e2ec2bea34983b2828c6a
diff --git a/CONFIG_SITE_ACQ400.local b/CONFIG_SITE_ACQ400.local
new file mode 100644
index 0000000..c8e033e
--- /dev/null
+++ b/CONFIG_SITE_ACQ400.local
@@ -0,0 +1,28 @@
+ifeq ($(T_A),linux-arm)
+BR_BASE_HDR = $(HOME)/PROJECTS/acq400_buildroot/output/host/arm-buildroot-linux-gnueabihf/sysroot
+BR_BASE_LIB = $(HOME)/PROJECTS/acq400_buildroot/output/target
+PVA_PY_CPPFLAGS = -I$(BR_BASE_HDR)/usr/include -I$(BR_BASE_HDR)/usr/include/python3.8
+PVA_PY_LDFLAGS = -L$(BR_BASE_LIB)/lib -L$(BR_BASE_LIB)/usr/lib
+PVA_PY_SYS_LIBS = boost_python38 python3.8
+PYTHON_VERSION = 3.8
+endif
diff --git a/src/pvaccess/Makefile b/src/pvaccess/Makefile
index 8e0a376..5581fdb 100644
--- a/src/pvaccess/Makefile
+++ b/src/pvaccess/Makefile
@@ -41,7 +41,7 @@ endif
# Build the Python pvaccess loadable library -LOADABLE_LIBRARY_HOST += pvaccess
+LOADABLE_LIBRARY += pvaccess
... this seems simple enough "when you know how", if you're planning a more canonical method, I'll be happy to try it.
Run time:
acq2106_182> /mnt/local/server.py
pvAccess Server v7.1.1-SNAPSHOT
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = local
Runtime: 27.08; Counter:    100000, Rate: 3.69 [kHz]
Runtime: 71.83; Counter:    200000, Rate: 2.78 [kHz]
Runtime: 122.71; Counter:    300000, Rate: 2.44 [kHz]
acq2106_182> /mnt/local/client.py
STARTING MONITOR for counter at 1590272853.3175964
STOP MONITOR at 1590272913.3814576
FINAL STATS:
counter: Received:   74716 (  1.24 [kHz]); Missed:       0 (  0.00%)
On 22/05/2020 19:46, Veseli, Sinisa wrote:
On 5/22/20 12:10 PM, Peter Milne wrote:
Hi Andrew
On 22/05/2020 16:27, Johnson, Andrew N. wrote:
Hi Peter,
On May 22, 2020, at 3:23 AM, Peter Milne via Tech-talk
<[email protected]<mailto:[email protected]>> wrote:
We have a requirement to run pvaPy on a linux-arm system.
The ARM system is configured to provide a full EPICS7, Boost lib.
Following
https://github.com/epics-base/pvaPy/blob/master/README.md
Custom Build:
Seems to build fine for EPICS_HOST_ARCH=linux-x86_64
It's also putting in hooks for linux-arm:
ls ./src/pvaccess/O.linux-arm
Makefile
pgm TOP ../../.. T_A linux-arm
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory
'/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-arm'
make[2]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess'
make[1]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src'
.... does nothing..
Is there any way to enable a cross-compile?
I don't see any PROD_HOST entries that could be changed to PROD, for
example.
The important entry in src/pvaccess/Makefile is the line
Since pvaPy is a dynamic library that gets loaded by Python, there
are no binaries to create so no use of the PROD or PROD_HOST
variables in the Makefile. Change the above to LOADABLE_LIBRARY and
it should start cross-compiling for your target.
Yes, that's it!. Thank you. And, really generically the same idea as
PROD_HOST, should have spotted that.
So, the good news, it's trying to build.
The bad news, there are errors, maybe just one:
/usr/include/python3.7m/pyconfig.h:4:10: fatal error: pyconfig-32.h:
So the next step is to get it to look at the linux-arm version of the
python headers rather than the HOST version..
... and that suddenly becomes really site-specific..
The build looks into configure/CONFIG_SITE.local file to determine any
site specific settings, which might also include a custom python build.
Specifically, variables that can be modified are PVA_PY_CPPFLAGS and
PVA_PY_LDFLAGS. In one of my builds I have the following:
bluegill2> more configure/CONFIG_SITE.local
PVA_PY_CPPFLAGS = -I/local/sveseli/MARTY/CONDA/include/python3.7m
-I/local/sveseli/MARTY/opt/boost-python-1.70.0/include
PVA_PY_LDFLAGS = -L/local/sveseli/MARTY/CONDA/lib
-L/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64 -lpython3.7m
PVA_PY_SYS_LIBS = boost_python37  boost_numpy37
PVA_API_VERSION = 482
PVA_RPC_API_VERSION = 482
HAVE_BOOST_NUM_PY = 0
HAVE_BOOST_PYTHON_NUM_PY = 1
PYTHON_VERSION = 3.7
PVA_PY_PYTHON = /local/sveseli/MARTY/CONDA/bin/python3
PVA_PY_PYTHONPATH =
/local/sveseli/MARTY/pvapy-sv/lib/python/3.7/linux-x86_64
PVA_PY_LD_LIBRARY_PATH =
/local/sveseli/MARTY/CONDA/lib:/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64
PVA_PY_SPHINX_BUILD = /local/sveseli/MARTY/CONDA/bin/sphinx-build
PVA_PY_EPICS_BASE = /local/sveseli/MARTY/opt/epics-7.0.3.1
PVA_PY_EPICS4_DIR = /local/sveseli/MARTY/opt/epics-7.0.3.1
PVA_PY_HOST_ARCH = linux-x86_64
PVA_PY_SETUP_SH =
/local/sveseli/MARTY/pvapy-sv/bin/linux-x86_64/pvapy_setup_full.3.7.sh
Automatic configuration should work for the host architecture that you
are building on, but at the moment it will likely not work for
cross-compiles.
Hopefully you and Sinisa can work out some way to adjust the build so
cross-builds like this can be configured more easily, but I suspect
it may always need some kind of manual configuration to enable it.
.. as confirmed above.
Should be possible to make a configure/ option of course..
Thanks again Andrew
Cheers
I talked to Andrew about making this easier.
Sinisa
Peter
- Andrew
Complexity comes for free, simplicity you have to work for.
Peter Milne
Director of Sales
www.d-tacq.com
Re: anyone ever crosscompile pvaPy? Veseli, Sinisa via Tech-talk
anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Re: anyone ever crosscompile pvaPy? Johnson, Andrew N. via Tech-talk
Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Prev: Re: EPICS 7 & Petalinux 2019.2 Heinz Junkes via Tech-talk
Next: Re: EPICS 7 & Petalinux 2019.2 Hu, Yong via Tech-talk
Prev: Re: anyone ever crosscompile pvaPy? Veseli, Sinisa via Tech-talk
Next: Re: anyone ever crosscompile pvaPy? Veseli, Sinisa via Tech-talk
