Subject: Re: anyone ever crosscompile pvaPy?
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 26 May 2020 13:35:36 +0000
Hi Peter,
Thanks for letting us know what you had to do to get this working. I'll try to make the build easier for cross compiles.
Best Regards,
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Peter Milne <[email protected]> on behalf of Peter Milne <[email protected]>
Sent: Saturday, May 23, 2020 5:36 PM
To: Veseli, Sinisa <[email protected]>; Johnson, Andrew N. <[email protected]>
Hi Sinisa
Thank you very much for your help as well as Andrew.
Reporting Success!: the server/client example pair works.
Method repeated below for reference (builds HOST and TARGET).
For general use, the key is to introduce $(T_A) HEADER and LIB search paths that are valid for the
cross compile to work. Also, I had to set HAVE_BOOST_PYTHON_NUM_PY = 0, surprised as not in the make config
If we can automate this with a template for "make configure" rather than hacking
the generated file configure/CONFIG_SITE.local, it would be better.
Best regards
Peter
Our embedded system uses buildroot, so that influences where to look for embedded headers and libs.
Proceeded as follows:
make configure EPICS_BASE=$HOME/PROJECTS/EPICS/base \
    EPICS4_DIR=$HOME/PROJECTS/EPICS/base PYTHON_VERSION=3
Modified CONFIG_SITE.local as follows.
pgm@staffa3 pvaPy]$ git diff 5048ae703c1ae1b5bd5e2ec2bea34983b2828c6a
diff --git a/CONFIG_SITE_ACQ400.local b/CONFIG_SITE_ACQ400.local
new file mode 100644
index 0000000..c8e033e
--- /dev/null
+++ b/CONFIG_SITE_ACQ400.local
@@ -0,0 +1,28 @@
+ifeq ($(T_A),linux-arm)
+BR_BASE_HDR = $(HOME)/PROJECTS/acq400_buildroot/output/host/arm-buildroot-linux-gnueabihf/sysroot
+BR_BASE_LIB = $(HOME)/PROJECTS/acq400_buildroot/output/target
+PVA_PY_CPPFLAGS = -I$(BR_BASE_HDR)/usr/include -I$(BR_BASE_HDR)/usr/include/python3.8
+PVA_PY_LDFLAGS = -L$(BR_BASE_LIB)/lib -L$(BR_BASE_LIB)/usr/lib
+PVA_PY_SYS_LIBS = boost_python38 python3.8
+PYTHON_VERSION = 3.8
+endif
diff --git a/src/pvaccess/Makefile b/src/pvaccess/Makefile
index 8e0a376..5581fdb 100644
--- a/src/pvaccess/Makefile
+++ b/src/pvaccess/Makefile
@@ -41,7 +41,7 @@ endif
  # Build the Python pvaccess loadable library
-LOADABLE_LIBRARY_HOST += pvaccess
+LOADABLE_LIBRARY += pvaccess
... this seems simple enough "when you know how", if you're planning a more canonical method, I'll be happy to try it.
Run time:
acq2106_182> /mnt/local/server.py
pvAccess Server v7.1.1-SNAPSHOT
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = local
Runtime: 27.08; Counter:    100000, Rate: 3.69 [kHz]
Runtime: 71.83; Counter:    200000, Rate: 2.78 [kHz]
Runtime: 122.71; Counter:    300000, Rate: 2.44 [kHz]
acq2106_182> /mnt/local/client.py
STARTING MONITOR for counter at 1590272853.3175964
STOP MONITOR at 1590272913.3814576
FINAL STATS:
counter: Received:   74716 (  1.24 [kHz]); Missed:       0 (  0.00%)
On 22/05/2020 19:46, Veseli, Sinisa wrote:
> Hi,
> On 5/22/20 12:10 PM, Peter Milne wrote:
>> Hi Andrew
>> On 22/05/2020 16:27, Johnson, Andrew N. wrote:
>>> Hi Peter,
>>> On May 22, 2020, at 3:23 AM, Peter Milne via Tech-talk
>>> <[email protected]<mailto:[email protected]>> wrote:
>>> We have a requirement to run pvaPy on a linux-arm system.
>>> The ARM system is configured to provide a full EPICS7, Boost lib.
>>> Following
>>> https://github.com/epics-base/pvaPy/blob/master/README.md
>>> Custom Build:
>>> Seems to build fine for EPICS_HOST_ARCH=linux-x86_64
>>> It's also putting in hooks for linux-arm:
>>> ls ./src/pvaccess/O.linux-arm
>>> Makefile
>>> pgm TOP ../../.. T_A linux-arm
>>> make[3]: Nothing to be done for 'install'.
>>> make[3]: Leaving directory
>>> '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-arm'
>>> make[2]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess'
>>> make[1]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src'
>>> .... does nothing..
>>> Is there any way to enable a cross-compile?
>>> I don't see any PROD_HOST entries that could be changed to PROD, for
>>> example.
>>> The important entry in src/pvaccess/Makefile is the line
>>> Since pvaPy is a dynamic library that gets loaded by Python, there
>>> are no binaries to create so no use of the PROD or PROD_HOST
>>> variables in the Makefile. Change the above to LOADABLE_LIBRARY and
>>> it should start cross-compiling for your target.
>> Yes, that's it!. Thank you. And, really generically the same idea as
>> PROD_HOST, should have spotted that.
>> So, the good news, it's trying to build.
>> The bad news, there are errors, maybe just one:
>> /usr/include/python3.7m/pyconfig.h:4:10: fatal error: pyconfig-32.h:
>> So the next step is to get it to look at the linux-arm version of the
>> python headers rather than the HOST version..
>> ... and that suddenly becomes really site-specific..
> The build looks into configure/CONFIG_SITE.local file to determine any
> site specific settings, which might also include a custom python build.
> Specifically, variables that can be modified are PVA_PY_CPPFLAGS and
> PVA_PY_LDFLAGS. In one of my builds I have the following:
> bluegill2> more configure/CONFIG_SITE.local
> PVA_PY_CPPFLAGS = -I/local/sveseli/MARTY/CONDA/include/python3.7m
> -I/local/sveseli/MARTY/opt/boost-python-1.70.0/include
> PVA_PY_LDFLAGS = -L/local/sveseli/MARTY/CONDA/lib
> -L/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64 -lpython3.7m
> PVA_PY_SYS_LIBS = boost_python37  boost_numpy37
> PVA_API_VERSION = 482
> PVA_RPC_API_VERSION = 482
> HAVE_BOOST_NUM_PY = 0
> HAVE_BOOST_PYTHON_NUM_PY = 1
> PYTHON_VERSION = 3.7
> PVA_PY_PYTHON = /local/sveseli/MARTY/CONDA/bin/python3
> PVA_PY_PYTHONPATH =
> /local/sveseli/MARTY/pvapy-sv/lib/python/3.7/linux-x86_64
> PVA_PY_LD_LIBRARY_PATH =
> /local/sveseli/MARTY/CONDA/lib:/local/sveseli/MARTY/opt/boost-python-1.70.0/lib/linux-x86_64
> PVA_PY_SPHINX_BUILD = /local/sveseli/MARTY/CONDA/bin/sphinx-build
> PVA_PY_EPICS_BASE = /local/sveseli/MARTY/opt/epics-7.0.3.1
> PVA_PY_EPICS4_DIR = /local/sveseli/MARTY/opt/epics-7.0.3.1
> PVA_PY_HOST_ARCH = linux-x86_64
> PVA_PY_SETUP_SH =
> /local/sveseli/MARTY/pvapy-sv/bin/linux-x86_64/pvapy_setup_full.3.7.sh
> Automatic configuration should work for the host architecture that you
> are building on, but at the moment it will likely not work for
> cross-compiles.
>>> Hopefully you and Sinisa can work out some way to adjust the build so
>>> cross-builds like this can be configured more easily, but I suspect
>>> it may always need some kind of manual configuration to enable it.
>> .. as confirmed above.
>> Should be possible to make a configure/ option of course..
>> Thanks again Andrew
>> Cheers
> I talked to Andrew about making this easier.
> Sinisa
>> Peter
>>> - Andrew
>>> Complexity comes for free, simplicity you have to work for.
Peter Milne
Director of Sales
www.d-tacq.com
anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Re: anyone ever crosscompile pvaPy? Johnson, Andrew N. via Tech-talk
Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Re: anyone ever crosscompile pvaPy? Veseli, Sinisa via Tech-talk
Prev: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Next: Re: Unpredictable behaviour with PyEpics Jaroslav Adam via Tech-talk
Prev: Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Next: Reminder: Codeathon Survey Johnson, Andrew N. via Tech-talk
