Subject: Re: Unpredictable behaviour with PyEpics
From: Jaroslav Adam via Tech-talk <[email protected]>
To: Simon Rose <[email protected]>
Date: Tue, 26 May 2020 10:13:17 -0400 (EDT)
Hi Simon,
verify what PYEPICS_LIBCA is pointing to. It is the library which PyEpics
is using to make connections.
From my experience with running PyEpics inside a PythonSoftIoc, the PYEPICS_LIBCA
should point to the same channel access library as the IOC is using.
With 3.14 base I have, it looks like this:
  export PYEPICS_LIBCA=/usr/local/epics/base-3.14.12.6/lib/linux-x86_64/libca.so
In PyEpics you can get the actual channel access library as
  epics.ca.find_libca()
Cheers,
Jarda
On Tue, 26 May 2020, Simon Rose via Tech-talk wrote:
Hello all –
I am trying to set up something to do some automated testing of communication with a running IOC with PyEpics, but unfortunately I am running
into some inconsistent behavior which makes it difficult to use as a reliable testing mechanism.
Specifically, if I have an IOC (EPICS base 7.0.3.1) up and running on the same machine, and run the following script:
from epics import PV
pv = PV(“test”)
assert pv.connect()
then most of the time, this works exactly as intended. However, somewhere around 1 in 5 times or so, it fails. I have tried to look at the
network traffic (using Wireshark) between the IOC and the python client, but unfortunately I don’t see a difference between successful and
unsuccessful connection attempts.
I am running both IOC and client inside a linux VM on my mac.
Any help would be appreciated,
Cheers,
Simon
Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Unpredictable behaviour with PyEpics Simon Rose via Tech-talk
Prev: Re: anyone ever crosscompile pvaPy? Veseli, Sinisa via Tech-talk
Next: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Prev: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
