1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SoftIOC and Labview
From: Gabriel Fedel via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 27 May 2020 08:26:43 +0200
Jalal,
I had the same problem with older versions of Labview. As soon I know the waveform implementation on Labview is wrong, so you shouldn't trust on it.
An alternative is CALab (https://www.helmholtz-berlin.de/zentrum/locations/it/software/exsteuer/calab/index_en.html), I've tried once and it looks much better than NI solution.
Best Regards
On 5/26/20 10:55 PM, Paul Sichta via Tech-talk wrote:
Jalal,
I was able to r/w using U32 data to a waveform record.
I'd have to dig a little to resurrect the details, perhaps later.
-ps
On Tue, May 26, 2020 at 3:36 PM Mostafa, Jalal (IPE) <[email protected] <mailto:[email protected]>> wrote:
    Writing double scalar values to a /ai /record works great.
    I tried both /aai /and /waveform /to write array values of
    doubles but no success.
    I am using LabView 2018 SP1. Do you have a list of what's working
    and what's not?
    Best,
    Jalal
    *From:* Paul Sichta <[email protected] <mailto:[email protected]>>
    *Sent:* Tuesday, May 26, 2020 9:28:39 PM
    *To:* Mostafa, Jalal (IPE)
    *Cc:* [email protected] <mailto:[email protected]>
    *Subject:* Re: SoftIOC and Labview
    Jalal,
    Can your labview write scalar values (e.g. to a longin record ) to
    your softioc?
    Have you tried writing your labview array to a waveform record on
    the softioc?
    Using earlier versions of the NI EPICS software, I seem to recall
    there were some data types that wouldn't work (I think double was
    OK).  I haven't tried the 2020 version but glad to see it has been
    updated.
    -ps
    On Tue, May 26, 2020 at 3:18 PM Mostafa, Jalal (IPE) via Tech-talk
        Hi All!
        I am trying to write an array of doubles from a LabView EPICS
        Client using EPICS Client I/O Server
        <http://joule.ni.com/nidu/cds/view/p/id/2533/lang/en> to a
        /softIoc/ instance with the corresponding record:
        /record(aai, "dummy:array")/
        /    field(DTYP,"Soft Channel")/
        /    field(NELM, "10")/
        /    field(FTVL, "DOUBLE")/
        I can see the LabVIEW being connected to this record but no
        written values to /softIoc/ instance. The issue is only
        happening on LabView but not when using other clients like caput
        for instance.
        What is the correct way to write array values from LabView to
        softIoc records?
        Best,
        Jalal
Gabriel Fedel
Ship 8, Floor 2.
EPICS Integrator
Integrated Control System Division
The European Spallation Souce
Odarslövsvägen 113
224 84 Lund
mobile Sweden: 0723356030
mobile International: +46723356030
Re: SoftIOC and Labview Ralph Lange via Tech-talk
SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Re: SoftIOC and Labview Paul Sichta via Tech-talk
Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Prev: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Next: Re: Unpredictable behaviour with PyEpics Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: SoftIOC and Labview Ralph Lange via Tech-talk
