1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Strange problem with areaDetector driver
From: Jörn Dreyer via Tech-talk <[email protected]>
Date: Fri, 29 May 2020 09:00:05 +0200
My CS-Studio is based on the 4.5.1 release. I build it myself to have a site specific version.
As I mentioned, I have successfully used it with aravisGigE Cameras, mainly from Basler.
For the IOC I set EPICS_CA_MAX_ARRAY_BYTES=800000000.
I have set a similar Value in CS-Studio But I can't check it at the moment. Yesterday I tried to build Phoebus and this somehow screwed up my CSS instalation.
Jörn
Am Donnerstag, 28. Mai 2020, 15:54:44 CEST schrieb Hu, Yong via Tech-talk:
> That is odd. We are using CS-Studio heavily for areaDetector at NSLS-II and
> have not seen such problems.
> Which version of CS-Studio are you using? What is the settings of
> EPICS_CA_MAX_ARRAY_BYTES both on your camera IOC side and on your CS-Studio
> side?
> We are using rules with PVs in IntensityGraph to automatically set Data
> width / height instead of manually configuring those parameters. I can send
> our .opi to you if you want (after your problems are fixed).
> Best luck!
> Yong Hu
> NSLS-II Controls Group
> On 5/28/20, 4:24 AM, "Tech-talk on behalf of Jörn Dreyer via Tech-talk"
> <[email protected] on behalf of [email protected]> wrote:
>     Hello
>     After some debugging, it turns out that the reason for the problem is
>     CS-Studio.
>     I have set up an opi Scene with an IntesityGraph for the Image. If I set
> the
 Data width and Data high to zero, the scene chanes from "No data" to
> "disconnected". If I set Data width to 4565 and Data height to 3520, the
> scene can not be loaded and results in java.lang.IllegalArgumentException.
> No further information is available. The scene can then even not get loaded
> into the OPI Editor and needs to be modified in a text editor.
>     For other cameras I was able to set the data height and data width
> parameters
 of the IntensityGraph to 2048 x 2048. Is there a size limit
> for this Widget? I did not find any hints obn that in the documentation.
>     Regards,
>     Jörn Drteyer
>     Am Donnerstag, 28. Mai 2020, 09:29:58 CEST schrieb Jörn Dreyer via
> Tech-talk:
>     > Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via
>     > Tech-talk:
>     > > > Closed the OPI screen that shows the image. Now the number of
>     > > > threads is
>     > > > constant. System load is at normal level.
>     > > When you saw the threads and high system load did you use top -H to
>     > > see
>     > > whether the threads with high CPU load were CSS threads or IOC
>     > > threads? I
>     > > suspect they are CSS threads.
>     > No they are all started from the IOC. After 300 threads spawned I
>     > decided to
 stop the IOC. I used
>     > ps -eLF | grep st.cmd | wc
>     > > > Will need some time to gat that going. Java on my system seems to
>     > > > have
>     > > > problem with the code.
>     > > ImageJ on both Linux and Windows comes with its own version of Java
>     > > in the
>     > > ImageJ/jre directory, so it should be completely independent of
>     > > your
>     > > system
>     > > version of Java.  Get the latest version of the ImageJ zip file and
>     > > install
>     > > it in your own directory so you don't need to worry about system
>     > > permissions, etc.
>     > I got it working, but there seems to be a problem that only half of
>     > the
>     > image is intrerpreted correctly. The ArrayType is UInt16 instead of
>     > UInt8.
>     > Will need to find out teh reason for that.
>     > Regards,
>     > Jörn
>     > > Mark
>     > > -----Original Message-----
>     > > From: Tech-talk <[email protected]> On Behalf Of Jörn
>     > > Dreyer
>     > > via Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM
>     > > To: [email protected]
>     > > Subject: Re: Strange problem with areaDetector driver
>     > > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
>     > > > Hi Jörn,
>     > > > > I ran into a severe problem in the image readout handler.
>     > > > > When calling doCallbackGenericPointer() the IOC creates every
>     > > > > time a
>     > > > > couple of  new threads and consumes lot of CPU power ( 300% on
>     > > > > a
>     > > > > quad core).
>     > > > First a few questions:
>     > > > Is this Linux or Windows?
>     > > Linux
>     > > > What frame rate are you using?
>     > > 0.5 Hz
>     > > > What plugins are running?
>     > > Only NDStdArray.
>     > > > Is the CS-Studio GUI on the same machine as the IOC or a
>     > > > different
>     > > > machine?
>     > > On the same machine
>     > > > The first thing to establish is whether the problem is the
>     > > > areaDetector IOC or the CS-Studio client.  I suggest you do the
>     > > > following:
>     > > > -  Disable all plugins except NDPluginStdArrays for testing.
>     > > Done,
>     > > > - Exit CS-Studio so there is no display client running.  What is
>     > > > the
>     > > > CPU load under those conditions?
>     > > threads is
>     > > > - Try the ImageJ viewer instead of CS-Studio for testing.  Does
>     > > > that
>     > > > also have the problem?
>     > > have
>     > > Regards,
>     > > Jörn
>     > > > Mark
>     > > > ________________________________
>     > > > From: Tech-talk <[email protected]> on behalf of Jörn
>     > > > Dreyer via Tech-talk <[email protected]> Sent: Wednesday, May
>     > > > 27,
>     > > > 2020 7:03 AM
>     > > > To: [email protected]
>     > > > Subject: Strange problem with areaDetector driver
>     > > > Hello,
>     > > > currently I have a very strange problem in a code I'm developing
>     > > > to
>     > > > read out cameras from ZWO. I ran into a severe problem in the
>     > > > image
>     > > > readout handler. When calling doCallbackGenericPointer() the IOC
>     > > > creates
>     > > > every time a couple of new threads and consumes lot of CPU power (
>     > > > 300%
>     > > > on a quad core). So after a very short time the system becomes
>     > > > unresponsive and has to be switched off. The image is 3520*4656
>     > > > bytes in
>     > > > size and is in monochrome mode, so UInt8 as data type.
Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
Prev: Announcing 2 New EPICS Releases: 3.15.8 and 7.0.4 Johnson, Andrew N. via Tech-talk
Next: Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
