> For the IOC I set EPICS_CA_MAX_ARRAY_BYTES=800000000.
That is nearly 1 GB. My understanding is that you should not use such a large value, because CA will actually allocate arrays of that size any time the actual array size is greater than 16 KB. It's better to set EPICS_CA_MAX_ARRAY_BYTES to be just a bit larger than the largest array you will actually use.
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Friday, May 29, 2020 2:00 AM
To: [email protected]
Subject: Re: Strange problem with areaDetector driver
My CS-Studio is based on the 4.5.1 release. I build it myself to have a site specific version.
As I mentioned, I have successfully used it with aravisGigE Cameras, mainly from Basler.
I have set a similar Value in CS-Studio But I can't check it at the moment. Yesterday I tried to build Phoebus and this somehow screwed up my CSS instalation.
Jörn
Am Donnerstag, 28. Mai 2020, 15:54:44 CEST schrieb Hu, Yong via Tech-talk:
> That is odd. We are using CS-Studio heavily for areaDetector at NSLS-II and
> have not seen such problems.
> Which version of CS-Studio are you using? What is the settings of
> EPICS_CA_MAX_ARRAY_BYTES both on your camera IOC side and on your CS-Studio
> side?
> We are using rules with PVs in IntensityGraph to automatically set Data
> width / height instead of manually configuring those parameters. I can send
> our .opi to you if you want (after your problems are fixed).
> Best luck!
> Yong Hu
> NSLS-II Controls Group
> On 5/28/20, 4:24 AM, "Tech-talk on behalf of Jörn Dreyer via Tech-talk"
> <[email protected] on behalf of [email protected]> wrote:
> Hello
> After some debugging, it turns out that the reason for the problem is
> CS-Studio.
> I have set up an opi Scene with an IntesityGraph for the Image. If I set
> the
Data width and Data high to zero, the scene chanes from "No data" to
> "disconnected". If I set Data width to 4565 and Data height to 3520, the
> scene can not be loaded and results in java.lang.IllegalArgumentException.
> No further information is available. The scene can then even not get loaded
> into the OPI Editor and needs to be modified in a text editor.
> For other cameras I was able to set the data height and data width
> parameters
of the IntensityGraph to 2048 x 2048. Is there a size limit
> for this Widget? I did not find any hints obn that in the documentation.
> Regards,
> Jörn Drteyer
> Am Donnerstag, 28. Mai 2020, 09:29:58 CEST schrieb Jörn Dreyer via
> Tech-talk:
> > Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via
> > Tech-talk:
> > > > Closed the OPI screen that shows the image. Now the number of
> > > > threads is
> > > > constant. System load is at normal level.
> > > When you saw the threads and high system load did you use top -H to
> > > see
> > > whether the threads with high CPU load were CSS threads or IOC
> > > threads? I
> > > suspect they are CSS threads.
> > No they are all started from the IOC. After 300 threads spawned I
> > decided to
stop the IOC. I used
> > ps -eLF | grep st.cmd | wc
> > > > Will need some time to gat that going. Java on my system seems to
> > > > have
> > > > problem with the code.
> > > ImageJ on both Linux and Windows comes with its own version of Java
> > > in the
> > > ImageJ/jre directory, so it should be completely independent of
> > > your
> > > system
> > > version of Java. Get the latest version of the ImageJ zip file and
> > > install
> > > it in your own directory so you don't need to worry about system
> > > permissions, etc.
> > I got it working, but there seems to be a problem that only half of
> > the
> > image is intrerpreted correctly. The ArrayType is UInt16 instead of
> > UInt8.
> > Will need to find out teh reason for that.
> > Regards,
> > Jörn
> > > Mark
> > > -----Original Message-----
> > > From: Tech-talk <[email protected]> On Behalf Of Jörn
> > > Dreyer
> > > via Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM
> > > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
> > > > Hi Jörn,
> > > > > I ran into a severe problem in the image readout handler.
> > > > > When calling doCallbackGenericPointer() the IOC creates every
> > > > > time a
> > > > > couple of new threads and consumes lot of CPU power ( 300% on
> > > > > a
> > > > > quad core).
> > > > First a few questions:
> > > > Is this Linux or Windows?
> > > Linux
> > > > What frame rate are you using?
> > > 0.5 Hz
> > > > What plugins are running?
> > > Only NDStdArray.
> > > > Is the CS-Studio GUI on the same machine as the IOC or a
> > > > different
> > > > machine?
> > > On the same machine
> > > > The first thing to establish is whether the problem is the
> > > > areaDetector IOC or the CS-Studio client. I suggest you do the
> > > > following:
> > > > - Disable all plugins except NDPluginStdArrays for testing.
> > > Done,
> > > > - Exit CS-Studio so there is no display client running. What is
> > > > the
> > > > CPU load under those conditions?
> > > threads is
> > > > - Try the ImageJ viewer instead of CS-Studio for testing. Does
> > > > that
> > > > also have the problem?
> > > have
> > > Regards,
> > > Jörn
> > > > Mark
> > > > ________________________________
> > > > Dreyer via Tech-talk <[email protected]> Sent: Wednesday, May
> > > > 27,
> > > > 2020 7:03 AM
> > > > Subject: Strange problem with areaDetector driver
> > > > Hello,
> > > > currently I have a very strange problem in a code I'm developing
> > > > to
> > > > read out cameras from ZWO. I ran into a severe problem in the
> > > > image
> > > > readout handler. When calling doCallbackGenericPointer() the IOC
> > > > creates
> > > > every time a couple of new threads and consumes lot of CPU power (
> > > > 300%
> > > > on a quad core). So after a very short time the system becomes
> > > > unresponsive and has to be switched off. The image is 3520*4656
> > > > bytes in
> > > > size and is in monochrome mode, so UInt8 as data type.
- Re: Strange problem with areaDetector driver Michael Davidsaver via Tech-talk
- Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
- Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
- Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
