1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to run IOC in docker containers properly
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 17 Jun 2020 14:18:12 -0500
On 06/17, Johnson, Andrew N. via Tech-talk wrote:
> Or GNU Screen similarly. I’m considering using a combination of GNU Screen (for multi-user access to the console, logging and screen history buffer recall) to run procServ -f (for IOC start/stop/restart) that runs a script which exec’s the IOC binary, although I haven’t actually tried that full combination yet.
Just curious, why do you need procServ at all?  You can run tmux (and
presumably Screen) as a systemd service if you want.  You can run tmux
commands to start, stop, and restart an IOC.
Lewis
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Prev: EPICS across subnets Randall Cayford via Tech-talk
Next: RE: EPICS across subnets Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
