Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Konrad, Martin" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 17 Jun 2020 23:26:16 +0000
On Jun 17, 2020, at 5:59 PM, Konrad, Martin <[email protected]> wrote:
Just curious, why do you need procServ at all? You can run tmux (and
presumably Screen) as a systemd service if you want. You can run
tmux commands to start, stop, and restart an IOC.
Compared to screen and tmux, procServ is lighter and less complex. It
can also restart a crashed IOC process and it prevents users who are in
the habit of pressing Ctrl-C + Ctrl-D for logging out from accidentally
shutting down the IOC.
procServ handles creating a pid.txt file for the IOC and will automatically restart an IOC that dies (if you ask it to) after some restart delay. If you don’t turn on the auto-restart (or you manually disabled it at runtime) you can connect to the console and restart it manually in a single key-press. I don’t know if it deletes the pid.txt file when the IOC goes down and recreates it on restart but I would expect it to.
The reason that we would run procServ inside GNU Screen is that our engineers love the ability to scroll back through the console history, seeing the output when the IOC booted, and even going back to earlier runs etc. procServ doesn’t have a history buffer at all, but screen (and presumably tmux) can provide that. We also rely on screen’s ability to support multiple people connecting to the console at once.
While we're at it I would like to propose a forth solution: How about
beefing up the IOC itself so it can listen on a socket for connections
to the IOC shell? This would come with a few advantages (some of them
might only apply to systems running systemd):
Thoughts? Maybe a project for the upcoming online codeathon?
I think that would be best implemented in an external module. You don’t have to use the iocsh to run your IOCs – you can write your own shell, or set up the stdin/stdout/stderr streams to point to something else before running iocsh() in the main() routine. You might want to disable readline if you do that though unless you are completely emulating a tty.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Prev: Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Next: Re: RE: No PV record found when build ASYN application on Windows shenzb--- via Tech-talk
Next: Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
