1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: GitHub Software Releases in support of EPICS Web Applications
From: Ryan Slominski via Tech-talk <[email protected]>
Date: Thu, 2 Jul 2020 15:03:13 +0000
Hi Simon,
   Your work looks interesting.   A few questions:
>> 1. Java Channel-Access Client Library "ca"
Should we combine / merge / abandon the JCA / CAJ library?   Looks like no one is really maintaining the old library and in fact it appears some of the original CAJ developers are working on the newer "ca" library.
Much of the code appears to be copied from JCA / CAJ anyways, with a modern API on top.   Though, it does seem the internal threading model has been a moving target through the years.  A few years ago I thought about using "ca", but noticed it was using an experimental LMax Distruptor with questionable benefit.   I see that has been removed: https://github.com/channelaccess/ca/issues/93, but I do see some other internal concurrency and threading model changes that could use some explanation.
>> 2. Wica-HTTP  (Wica = "Web Interface for Control Applications")
There are a lot of these now.  I'll update my list here:
A comparison might be useful.   One thing that jumps out is that you use Server Side Events (SSE).  These weren't really an option a few years ago due to Internet Explorer not supporting them.   Now that Microsoft Edge uses Chromium under the hood that's no longer an issue.
>> 3. Wica-JS
Looks like you've got to be web developer to use this library?     Maybe a builder interface like EDM/CSS is in the works?  For example: https://github.com/JeffersonLab/puddysticks
Re: GitHub Software Releases in support of EPICS Web Applications Simon Rees via Tech-talk
Prev: FW: Opening opi/bob files into display mode from the terminal Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Next: Many EPICS Applications in Docker Images Philipp Klaus via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: GitHub Software Releases in support of EPICS Web Applications Simon Rees via Tech-talk
Next: Re: GitHub Software Releases in support of EPICS Web Applications Simon Rees via Tech-talk
