Subject: Re: Masking values in combo boxes
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 6 Jul 2020 18:33:40 +0200
On Mon, 6 Jul 2020 at 16:21, Mark Rivers via Tech-talk <[email protected]> wrote:
?  I have four options, and mbbo did the trick. May I assume, that this is the intended way to implement such options (At least up to 16)?
Yes.  If there are only 2 options you can also use the bo/bi records.
More modern terms for the concepts implemented in the digital EPICS records would be:
bi/bo:    Boolean
mbbi/mbbo:    Enum
mbbiDirect/mbboDirect:    Bitmask
longin/longout:    Integer
Cheers,
~Ralph
Masking values in combo boxes Nonn, Patrick via Tech-talk
Re: Masking values in combo boxes Jemian, Pete R. via Tech-talk
Re: Masking values in combo boxes Nonn, Patrick via Tech-talk
Fwd: Masking values in combo boxes Mark Rivers via Tech-talk
Prev: Fwd: Masking values in combo boxes Mark Rivers via Tech-talk
Next: Re: Masking values in combo boxes Maren Purves via Tech-talk
