1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Re: Epics iocInit()
To: "Mark Rivers" <[email protected]>
Date: Mon, 6 Jul 2020 17:09:03 +0800
Hi Mark
     Firstly, thank you very much for you relpy.
Now I will answer your some question:
- It looks like this is Windows, correct?
 Yes, this is Windows
-  What does the error message say in English?
 the error message mean:There was a problem that caused the program to stop working properly.Please close the program
- What versions of EPICS base and other modules (asyn, etc.)?
 EPICS base ver:base-7.0.3.1  asyn ver:asyn-R4-37  busy ver: busy-R1-7-2 std-R3-6 .... and so on
- It looks like tucsen.com makes cameras.  Is this an areaDetector IOC?
 YES our campany makes cameras, I'm a software engineer from tucsen.
  • YES,this is areaDetector IOC We want to develop our camera on Epics software.
- What IOC application is it?  Is it one you wrote, or one you got from some EPICS module?
year I refer to ioc from Andor3
- Do you get any output in the IOC console before you get that error?  If the error is a missing DLL then you probably won't.
  • I added the necessary DLL files,So I think it should not be caused by DLL
- If you do get output then please send the complete output.
    • It crashes when it runs and there's no output, right
    • sometimes I find if i
      • Adding this function( createParam(TucsenPixelEncodingString,    asynParamInt32,   &TucsenPixelEncoding);
      • ) will cause the program to crash
      • In particular this enumeration(asynParamInt32
        • Could I trouble you for help,thk
Date: 2020-07-04 22:10
Subject: Re: Epics iocInit()
There is way too little information in your message to answer your question.  Most of the people on tech-talk cannot read Chinese so we don't know what the error message says.  But even if we did we need to know a lot more.
From: Tech-talk <[email protected]> on behalf of fandayu--- via Tech-talk <[email protected]>
Sent: Friday, July 3, 2020 12:31 AM
Subject: Epics iocInit()
hi
[cid:_Foxmail.1@ba3ab396-468b-e51a-e09a-1eb639df79e2]
The code crashes when it is iocInit() .Do you have any other good Suggestions
Re: Re: Epics iocInit() fandayu--- via Tech-talk
RE: Re: Epics iocInit() Mark Rivers via Tech-talk
Prev: RE: oagwish and sdds - tktable not found Ernesto Paiser via Tech-talk
Next: Re: Re: Epics iocInit() fandayu--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Epics iocInit() Mark Rivers via Tech-talk
