Ø
YES our campany makes cameras, I'm a software engineer from tucsen.
Ø
YES,this is areaDetector IOC We want to develop our camera on Epics software>..
Ø
> - What IOC application is it? Is it one you wrote, or one you got from some EPICS module?
Ø
year I refer to ioc from Andor3
Do you mean it is an areaDetector driver that you wrote based on ADAndor3?
Do you know that there is already an areaDetector driver for Tucsen cameras? It was written by David Vine. I don’t know the current status.
https://github.com/djvine/ADTucsen
If you were not aware of that, it might be a better place to start than the ADAndor3 driver.
If you do the following:
cd to your iocBoot/iocXXX directory, where XXX is whatever you named it.
Type the following command:
..\..\bin\windows-x64\XXX.exe st.cmd
where XXX is the name of your application, what to you see? Please send the complete output.
Ø
Could you please tell me,Is Andor areaDetector-camera the software your helped develop or they developed it themselves?
The EPICS areaDetector ADAndor3 driver was written by the EPICS community, including me. It was not written by Andor.
Firstly, thank you very much for you relpy.
Now I will answer your some question:
- It looks like this is Windows, correct?
- What does the error message say in English?
the error message mean:There
was a problem that caused the program to stop working properly.Please close the program
- What versions of EPICS base and other modules (asyn, etc.)?
EPICS base ver:base-7.0.3.1 asyn ver:asyn-R4-37 busy ver: busy-R1-7-2 std-R3-6 .... and so on
- It looks like tucsen.com makes cameras. Is this an areaDetector IOC?
YES,this is areaDetector IOC We want to develop our camera on Epics software.
- Do you get any output in the IOC console before you get that error? If the error is a missing DLL then you probably won't.
I added the necessary DLL files,So I think it should not be caused by DLL
- If you do get output then please send the complete output.
o
It crashes when it runs and there's no output, right
o
sometimes I find if i
Adding this function( createParam(TucsenPixelEncodingString, asynParamInt32,
&TucsenPixelEncoding);
) will cause the program to crash
In particular this enumeration(asynParamInt32
Could I trouble you for help,thk
Subject: Re: Epics iocInit()
There is way too little information in your message to answer your question. Most of the people on tech-talk cannot read Chinese so we don't know what
the error message says. But even if we did we need to know a lot more.
Sent: Friday, July 3, 2020 12:31 AM
The code crashes when it is iocInit() .Do you have any other good Suggestions
