Subject: |
Process at Init of mbbo-record |
"Nonn, Patrick via Tech-talk" <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Wed, 8 Jul 2020 14:47:22 +0200 (CEST) |
I observe some odd behaviour. I have changed a longout record to an mbbo record, either with passive scan and pini=1. This record is loaded eight times with different macros. After the change to mbbo, the 5th instance of this record is not processed during init (VAL is set, RVAL is 0). This is true, even if the sequence, in which the different instances are loaded, are switched. Could this be a timing issue of some sort?
Greetings
Patrick
Fw: Re: Epics iocInit() fandayu--- via Tech-talk
Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
<2020>
2025
2026
RE: Get/Set Local Variable in motorAxis From sub Record Pearson, Matthew R. via Tech-talk
RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
<2020>
2025
2026
