1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Process at Init of mbbo-record
To: "'Nonn, Patrick'" <[email protected]>
Date: Wed, 8 Jul 2020 13:53:15 +0000
Hi Patrick,
I forgot to CC tech-talk on my original reply.
Your st.cmd got stripped out by the mail system, please rename to st.cmd.txt before attaching.
Please use the details=5 flag on the dbpr commands, e.g.
dbpr Tst/4Config/targetStream 5
Did you check carefully for any warnings or errors in the iocsh output when starting the IOC?
-----Original Message-----
Sent: Wednesday, July 8, 2020 8:25 AM
Subject: Re: Process at Init of mbbo-record
the db-file and the start-script, where it is loaded, is attached. I have also attached the req files used to set the record via save_restore, just in case. The dbpr output is:
epics> dbpr Tst/4Config/targetStream
ASG :               DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: Tst/4Config/targetStream          RBV : 0
RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL : 3
I have also looked at the mbbo record loaded afterwards:
epics> dbpr Tst/4Config/logLevel
DISV: 1             NAME: Tst/4Config/logLevel              RBV : 0
RVAL: 3             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL : 3
and as you can see, it is processed correctly at init, as is the targetStream record before:
epics> dbpr Tst/3Config/targetStream
DISV: 1             NAME: Tst/3Config/targetStream          RBV : 0
VAL : 3
and afterwards:
epics> dbpr Tst/5Config/targetStream
DISV: 1             NAME: Tst/5Config/targetStream          RBV : 0
VAL : 3
Patrick
----- Original Message -----
To: "Patrick Nonn" <[email protected]>
Sent: Wednesday, 8 July, 2020 15:07:42
Can you show:
- The database file
- The commands to load it 8 times
- The output of the following command at the iocsh, where (record) is the name of the 5'th record loaded.
dbpr (record) 5
From: Tech-talk <[email protected]> on behalf of Nonn, Patrick via Tech-talk <[email protected]>
Sent: Wednesday, July 8, 2020 7:47 AM
To: tech-talk
Subject: Process at Init of mbbo-record
I observe some odd behaviour. I have changed a longout record to an mbbo record, either with passive scan and pini=1. This record is loaded eight times with different macros. After the change to mbbo, the 5th instance of this record is not processed during init (VAL is set, RVAL is 0). This is true, even if the sequence, in which the different instances are loaded, are switched. Could this be a timing issue of some sort?
Greetings
Patrick
Re: Process at Init of mbbo-record Nonn, Patrick via Tech-talk
Prev: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Next: RE: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Process at Init of mbbo-record Nonn, Patrick via Tech-talk
Next: Re: Process at Init of mbbo-record Nonn, Patrick via Tech-talk
