1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Process at Init of mbbo-record
From: "Nonn, Patrick via Tech-talk" <[email protected]>
Date: Wed, 8 Jul 2020 16:26:36 +0200 (CEST)
here the dbpr outputs with high detail level:
epics> dbpr Tst/4Config/targetStream 5
ACKS: NO_ALARM      ACKT: YES           ASG :               ASP : PTR (nil)
BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00            COSV: NO_ALARM
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b806af70
DSET: PTR 0x7f19cac50a40                DTYP: ChimeraTK     EIST:
EISV: NO_ALARM      EIVL: 0x0           ELST:               ELSV: NO_ALARM
ELVL: 0x0           EVNT:               FFST:               FFSV: NO_ALARM
FFVL: 0x0           FLNK: CONSTANT      FRST:               FRSV: NO_ALARM
FRVL: 0x0           FTST:               FTSV: NO_ALARM      FTVL: 0x0
FVST:               FVSV: NO_ALARM      FVVL: 0x0
IVOA: Continue normally                 IVOV: 0             LALM: 3
LCNT: 0             LSET: PTR 0x5626b801ec80                MASK: 0
MLIS: ELL 1 [0x7f1964041eb8 .. 0x7f1964041eb8]
MLOK: b0 a6 03 b8 26 56 00 00           MLST: 3
NAME: Tst/4Config/targetStream          NIST:               NISV: NO_ALARM
NIVL: 0x0           NOBT: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
OMSL: supervisory   ONST: Logfile Only  ONSV: NO_ALARM      ONVL: 0x1
ORAW: 0             ORBV: 0
OUT : INST_IO @ChimeraTKApp processes/4/config/targetStream PACT: 0
PHAS: 0             PINI: YES           PPN : PTR (nil)     PPNR: PTR (nil)
PRIO: LOW           PROC: 0             PUTF: 0             RBV : 0
RDES: PTR 0x5626b7b956c0                RPRO: 0
RSET: PTR 0x7f19cac4b740                RVAL: 0             SCAN: Passive
SDEF: 1             SDIS: CONSTANT      SEVR: NO_ALARM      SHFT: 0
SIML: CONSTANT      SIMM: NO            SIMS: NO_ALARM      SIOL: CONSTANT
SPVT: PTR (nil)     STAT: NO_ALARM      SVST:               SVSV: NO_ALARM
SVVL: 0x0           SXST:               SXSV: NO_ALARM      SXVL: 0x0
TEST:               TESV: NO_ALARM      TEVL: 0x0           THST: No Logging
THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256869741
TPRO: 0             TSE : 0             TSEL: CONSTANT      TTST:
TTSV: NO_ALARM      TTVL: 0x0           TVST:               TVSV: NO_ALARM
TVVL: 0x0           TWST: StdOut Only   TWSV: NO_ALARM      TWVL: 0x2
UDF : 0             UDFS: INVALID       UNSV: NO_ALARM      VAL : 3
ZRST: Logfile + StdOut                  ZRSV: NO_ALARM      ZRVL: 0x0
epics> dbpr Tst/3Config/targetStream 5
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b80871a0
LCNT: 0             LSET: PTR 0x5626b801e9c0                MASK: 0
MLIS: ELL 1 [0x7f1964042490 .. 0x7f1964042490]
MLOK: d0 a5 03 b8 26 56 00 00           MLST: 3
NAME: Tst/3Config/targetStream          NIST:               NISV: NO_ALARM
ORAW: 3             ORBV: 0
OUT : INST_IO @ChimeraTKApp processes/3/config/targetStream PACT: 0
RSET: PTR 0x7f19cac4b740                RVAL: 3             SCAN: Passive
THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256855004
epics> dbpr Tst/5Config/targetStream 5
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b8088680
LCNT: 0             LSET: PTR 0x5626b801ef40                MASK: 0
MLIS: ELL 1 [0x7f19640418e0 .. 0x7f19640418e0]
MLOK: 90 a7 03 b8 26 56 00 00           MLST: 3
NAME: Tst/5Config/targetStream          NIST:               NISV: NO_ALARM
ORAW: 3             ORBV: 0
OUT : INST_IO @ChimeraTKApp processes/5/config/targetStream PACT: 0
THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256896931
I did check the errors and warnings, and did find nothing. But four eyes see more...
Adding 8 processes.
Adding filesystem monitor for: sda3 mounted at: / -->0
Adding filesystem monitor for: sda4 mounted at: /home -->1
Adding network monitor for device: enp2s0f1 -->0
Adding network monitor for device: wlp3s0 -->1
#!/home/countzero/ChimeraTK/install/bin/watchdog-server
#< envPaths
dbLoadDatabase("../dbd/ChimeraTK.dbd",0,0)
ChimeraTK_registerRecordDeviceDriver(pdbbase)
chimeraTKConfigureApplication("ChimeraTKApp", 100)
## Setup autosave
set_requestfile_path("../db/")
set_savefile_path("../autosave/")
## Load record instances
dbLoadRecords("../db/WatchdogServer-main.db", "SERVER=Tst")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=0")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=1")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=2")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=3")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=4")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=5")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=6")
dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=7")
save_restoreSet_DatedBackupFiles(0)
save_restoreSet_Debug(0)
save_restoreSet_NumSeqFiles(3)
save_restoreSet_SeqPeriodInSeconds(3600)
#set_pass0_restoreFile("WatchdogServer-main.sav", "SERVER=Tst")
set_pass1_restoreFile("WatchdogServer-main.sav", "SERVER=Tst")
#set_pass0_restoreFile("Processes.sav", "SERVER=Tst")
set_pass1_restoreFile("Processes.sav", "SERVER=Tst")
iocInit()
Starting iocInit
## EPICS R3.16.2
## EPICS Base built Jun 11 2020
reboot_restore: entry for file 'WatchdogServer-main.sav'
reboot_restore: Found filename 'WatchdogServer-main.sav' in restoreFileList.
*** restoring from '../autosave/WatchdogServer-main.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'WatchdogServer-main.sav'
reboot_restore: entry for file 'Processes.sav'
reboot_restore: Found filename 'Processes.sav' in restoreFileList.
*** restoring from '../autosave/Processes.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'Processes.sav'
#postEvent 1
create_monitor_set("WatchdogServer-main.req", 60, "SERVER=Tst")
create_monitor_set("Processes.req", 60, "SERVER=Tst")
Processes.sav: 136 of 136 PV's connected
WatchdogServer-main.sav: 25 of 25 PV's connected
epics>
Patrick
----- Original Message -----
To: "Patrick Nonn" <[email protected]>
Cc: "tech-talk" <[email protected]>
Sent: Wednesday, 8 July, 2020 15:53:15
Subject: RE: Process at Init of mbbo-record
Hi Patrick,
I forgot to CC tech-talk on my original reply.
Your st.cmd got stripped out by the mail system, please rename to st.cmd.txt before attaching.
Please use the details=5 flag on the dbpr commands, e.g.
Did you check carefully for any warnings or errors in the iocsh output when starting the IOC?
-----Original Message-----
Sent: Wednesday, July 8, 2020 8:25 AM
the db-file and the start-script, where it is loaded, is attached. I have also attached the req files used to set the record via save_restore, just in case. The dbpr output is:
ASG :               DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: Tst/4Config/targetStream          RBV : 0
RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL : 3
I have also looked at the mbbo record loaded afterwards:
epics> dbpr Tst/4Config/logLevel
DISV: 1             NAME: Tst/4Config/logLevel              RBV : 0
RVAL: 3             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL : 3
and as you can see, it is processed correctly at init, as is the targetStream record before:
DISV: 1             NAME: Tst/3Config/targetStream          RBV : 0
VAL : 3
and afterwards:
DISV: 1             NAME: Tst/5Config/targetStream          RBV : 0
VAL : 3
Patrick
Sent: Wednesday, 8 July, 2020 15:07:42
Can you show:
- The database file
- The commands to load it 8 times
- The output of the following command at the iocsh, where (record) is the name of the 5'th record loaded.
dbpr (record) 5
From: Tech-talk <[email protected]> on behalf of Nonn, Patrick via Tech-talk <[email protected]>
Sent: Wednesday, July 8, 2020 7:47 AM
To: tech-talk
Subject: Process at Init of mbbo-record
I observe some odd behaviour. I have changed a longout record to an mbbo record, either with passive scan and pini=1. This record is loaded eight times with different macros. After the change to mbbo, the 5th instance of this record is not processed during init (VAL is set, RVAL is 0). This is true, even if the sequence, in which the different instances are loaded, are switched. Could this be a timing issue of some sort?
Greetings
Patrick
#< envPaths
## Setup autosave
iocInit()
#postEvent 1
RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
Process at Init of mbbo-record Nonn, Patrick via Tech-talk
Prev: RE: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
Next: RE: Get/Set Local Variable in motorAxis From sub Record Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
Next: RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
