Hi Andrew,
thanks for that. I tested the <pv_name>.$ syntax in phoebus, and it works there, as well.
Patrick
Sorry I worded that reply badly, the field modifier of course comes after the (optional) field name. You can only omit the dot when you’re addressing the VAL field with no modifiers.
And of course CA clients should normally treat a channel name as an opaque string, since only the specific server knows how to parse it properly. Non-IOC servers using the PCAS or some other server library can use totally different syntax and
semantics for names.
- Andrew
On Jul 13, 2020, at 11:25 AM, Johnson, Andrew N. via Tech-talk < [email protected]> wrote:
Hi Patrick,
On Jul 13, 2020, at 4:08 AM, Nonn, Patrick via Tech-talk < [email protected]> wrote:
I would like to clarify, that you have to address the VAL field of a PV specifically and add a $ to that. "caput -S <pv_name>$" will not work. (Because caput addresses <pv_name>$.VAL, that way.) The same is true for CSS, incl. phoebus. I'm mentioning
that, because I actually found some old tech-talk entry before I started this thread, where it was also mentioned that you have to add a $ to the pv name, which did not work for that reason.
You can omit the VAL field name, but you must still include the dot which marks the end of the record name and tells the name lookup code that whatever follows is a field modifier. If there’s no field name after that modifier will
apply to the default field (which is VAL at the moment but might not always be with new record types in future releases of EPICS). Thus “caget -S <pv_name>.$” will work for the lsi and lso record types.
- Andrew
Let me summarize, what to do, if your lso/lsi won't hold more than 40 characters:
- check the field SIZV, it defaults to 41 (=40 characters)
- check the environment variables EPICS_CA_MAX_ARRAY_BYTES and EPICS_CA_AUTO_ARRAY_BYTES
For more information, check:
https://epics.anl.gov/base/R3-16/1-docs/RELEASE_NOTES.html
- for caput/caget: make sure you use the -S option
- for caput/caget and CSS: Address the pv as <pv_name>.VAL$
- for CSS, incl. Phoebus: check the "max_array_bytes"-setting
- for CSS Phoebus: make sure to set the format property to "String"
Have I forgotten something?
Complexity comes for free, simplicity you have to work for.
- Re: Long String support in phoebus Ralph Lange via Tech-talk
- Long String support in phoebus Nonn, Patrick via Tech-talk
- Re: Long String support in phoebus Mark Rivers via Tech-talk
- Re: Long String support in phoebus Nonn, Patrick via Tech-talk
- Re: Long String support in phoebus Johnson, Andrew N. via Tech-talk
AW: Integrating picoscopes into the EPICS control system Loeher, Bastian Dr. via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
