1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Long String support in phoebus
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 14 Jul 2020 11:54:53 +0200
Just for the record:
Channel Access has no concept of "records" or "fields". (These are concepts of the EPICS Database.)
In the context of CA, a PV is basically anything that a server will resolve as something that is accessible.
The convenience fallback of using a record's value field if no field is specified is implemented in the EPICS Database - CA is unaware that this is happening.
Consequently, the "<pv_name>" in this thread should rather be "<record_name>", as the related statements apply when connecting to an EPICS IOC Database.
Cheers,
~Ralph
Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Mark Rivers via Tech-talk
Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Johnson, Andrew N. via Tech-talk
Prev: Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Next: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Stream device - general concept how to use Christian Pauly via Tech-talk
