Thanks for the advice
Linking the set-records to the corresponding get-status records is
indeed a very good idea.
Connecting all the get-records together via forward-links sounds a bit
unpractical for maintenance.
Maybe then its better to use a single (or nested if one is not enough)
Fanout records for regular scanning of all status-records ?
I am still wondering why there is nothing foreseen to get prompt
execution of a record (and its protocol) once its read via caget (prior
to returning the result).
This would be similar to the PP ProcessPassive flag mechanism when using
input links.
- Re: Stream device - general concept how to use Ralph Lange via Tech-talk
- Stream device - general concept how to use Christian Pauly via Tech-talk
- Re: Stream device - general concept how to use Mark Rivers via Tech-talk
- Re: Stream device - general concept how to use Arnold, Ned D. via Tech-talk
Re: Modbus alarms question John Dobbins via Tech-talk
Re: Stream device - general concept how to use Konrad, Martin via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
