Subject: Re: Stream device - general concept how to use
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: Christian Pauly <[email protected]>, "Christian Pauly via Tech-talk" <[email protected]>
Date: Thu, 16 Jul 2020 16:00:22 +0000
Hi Christian,
At first sight it might sound like a bad idea to poll devices
periodically: If the values are used rarely this means a lot of
unnecessary communication to the device. However, there are a few points
to keep in mind:
- Every once in a while a PV might draw a lot of attention. If you're
talking to the device for each client that requests the data you might
overwhelm a device with a slow interface or controller in the moment you
need it the most. If you're polling load is always the same.
- Every once in a while devices fail and stop talking. I usually want to
know right away (alarm). If you aren't polling the device how do you know?
- Polling only affects the connection between the IOC and the device.
Generally no Channel Access updates are posted if the value hasn't
changed (or within the MDEL). This usually keeps overall traffic on the
network reasonably low.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Prev: Re: Stream device - general concept how to use Christian Pauly via Tech-talk
Next: Re: Stream device - general concept how to use Ralph Lange via Tech-talk
Prev: RE: Stream device - general concept how to use Mark Rivers via Tech-talk
Next: Pure Python IOC (CAProcess issue) Simon Reiter via Tech-talk
